Hey, Carl -
First thing to check would be the electrical connections on the back of the gauge panel. Not too difficult to remove.
Once you have access, you'll see that there is a sheet of plastic on which is a printed circuit for all the gauges and dash lights. Not the best design, but if kept in order, it is functional. Disconnect all the terminals, clean them, and apply dielectric grease. Be careful cleaning the copper plating, as it's pretty thin on the plastic. Should clear up your problems, and you may even have the bonus of brighter dash lights! (While you're in there, pull the green plastic bubbles for the lights and clean them up - will help with brightness as well.)
Mickey
