TR 3 question
jayhawk
Hi folks-- getting my car closer to paint but am puzzled as to how the leather/vinyl trim piece arching up from the rear of the door jam to the top/front of the rear fender comes off. It's about 12 inches long and unlike the other cockpit trim pieces, has no visible screws. Don't want to just force it if there's some trick.
Thanks!
Geo Hahn
ISTR it is only held by the screws that hold the dogleg panel in place... but once they are out it is still a real snug fit.
You might try putting a block of wood against the inside edge of the piece and gently tapping (up) on it with a hammer -- see if it budges.
This is an interesting piece to recover as it has compound curves -- sort of a 3-handed operation with water, heat, glue and lots of grunting and swearing. I made a sort of vise-mounted jig to hold the metal in place while I tugged and stretched the leather into position.
Mickey Richaud
[ QUOTE ]
[/ QUOTE ]
What an understatement! When I did mine, it finally came out looking somewhat presentable. Over time, it has stretched at the bottom, just before it makes that compound curve upwards. Now it's all bunched up, and has to be redone. Not a fun job!
(Geo - want to do mine for me? /ubbthreads/images/graemlins/jester.gif)
Geo Hahn
[ QUOTE ]
[/ QUOTE ]
Wouldn't want to deprive you of the fun. Here's the jig I made. The metal cap piece is held in place with small nails thru the existing holes used for the dogleg panel screws.
dogleg1
dogleg2
Soaked the leather in warm water for quite awhile, also used a heat gun very gently to make it more pliable.
dogleg3
dogleg4
J
jayhawk
Hey Geo-- What a great help! Tips and pics to boot! I wasn't sure people would even understand what part I was talking about.
A jig is a good idea-- that rascal is a weird shape--no wonder I've seen so many with wrinkles.
Mickey Richaud
YES - Thanks! I plan to redo mine over the winter, along with a few other items that I wasn't initially happy with. This will come in handy.
Mickey
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
R TR6 Starter wiring question Triumph 6
K TR2/3/3A TR-3B carb question Triumph 13
