Towed Home
Will_Ringrose
Im still not sure yet what happened. The motor started making this bad ratting noise heading down the highway. The sound is coming from the center of motor under load or at anything above 2,500RPM. The higher the RPM the louder and faster the noise is.
My friend that towed me home thinks it may be a bad crank barring. But I am clueless.
Any thoughts?
Where should I even start?
The 69 Bug is off the road right now as well, the Distro points failed. I have new ones showing up tomorrow, so I am stuck at home until they do.
W
Will_Ringrose
U-Hual Had a Washington plate, I find this funny. I am from Yakima Washington.
DougF
First, don't run the engine. Drop the oil pan and pull the main bearing caps. Be aware that all caps are numbered and need to go back to where they were. Do one at a time. Inspect all of the bearings and the crank surfaces they ride on for scoring. If not the mains, move on to the rod bearings.
If the crank is damaged and reparable, it will have to be turned and new bearings installed. If you are lucky and there isn't heavy wear on the crank, you can replace the bearings and be back on the road in no time.
While in there, it's a good time to replace the thrust washer.
Hopefully, like the TR6, this work can be done with the engine in place on the GT6.
hondo402000
Not sure but does the crank shaft break in a GT6 where the TR6 Crank breaks?
Hopefully its not a broken crankshaft
Hondo
tr8todd
Sounds like you ran low on oil pressure and damaged the bearings. My first guess would be rods. A buddy of mine just had the same thing happen on his v8 Explorer. I helped him replace the rod bearings and all seems well. For now.
W
Will_Ringrose
Well the oil is a little dirty, i was going to change it this weekend.
I can not seem to get the oil pan off, there are 3 bolts that I can not seem to get to. The one right above the rack and pinion, and the 2 going down the drivers side. Those 3 bolts are giving me such an issue getting to them. I may have to pull the motor out.
DougF
I'd loosen the steering rack and move it out of the way before pulling the engine. Find a socket or wrench that will fit or alter one. Even if you have the proper hoist and engine stand, etc., you will have too many hours wrapped up prepping, pulling, installing and putting back together on a car that you probably want to get back into service asap.
Plus, if you pull the engine, it's too easy to get into the "While it's out, I might as well do this" mode. Before you know it, the car is off the road for an extended period of time.
If you don't have one, buy or borrow a torque wrench and follow the shop manual on proper settings.
Good Luck!
W
Will_Ringrose
Well parts for my 69 Bug just showed up, that should be back on the road tonight or tomorrow.
But I got some bad news today (got laid-off) so the GT6 might be sitting a bit longer then I would have hoped for.
CJD
Sorry to hear Will...it's definitely true that when it rains, it pours. Best of luck!
John
G
Oh goodness. Well, look at the bright side. At least you have time to fix the 6.
W
Will_Ringrose
Well, looks like I am going to have pull the the entire front end apart, as I was trying to get the rack and pinon out of the way the mounting bolts snapped.
On top of that, there a a nice rust hole on the frame. It is where the outrigger on the passenger side meets the frame rail.
fun stuff
DNK
That is really the HARD way to do it I would suspect.
On the Wedge you just undo the mount bolts and jack up the nose of the motor with the damper
booley
Oh dear!! things go from bad to worse... on the rust issue, that is one of the perils of using the GT as a daily driver
Best of luck Will
CinneaghTR
Will_Ringrose said:
Will,
Sorry to hear about your troubles and good luck fixing your car. You are experiencing what so many people have gone through in the past when the cars were not that old.
I noticed that you have year-of-manufacture (YOM) plates on your 50+ mile daily driver. Can you assign a YOM plate to regular MD plates?
Good luck!
W
Will_Ringrose
thats where I Break the rules a little. In MD you can do it with Historic registered cars.
The historic cars should only be driving to and from shows and maintenance. how ever thy did add "occasional transportation" in to the mix when you register Historic.
I have asked many officers in different counties and no one can tell me what they define "occasional" as.
Its been 3 years and not once I have been stopped for it. However, have have even been stop on a week day in the middle of the day and given a written warning for speeding. Nothing came up about the plates at that time.
DanB
In WV you have the option with you AY tags. Pay the full amount and register is as a daily driver, or pay a lot less and register as an antique.
I agree with the rod-knock assessment, BTW
Dan B
Sopwith_Camel towed home Jaguar 10
Darrell_Walker Towed home Triumph 12
RedTR3 Engine noise - towed home - what could it be? Triumph 44
glemon Series 1.5-2 E type, flat towed Spotted 0
hondo402000 TR6 TR6 towed on Sat night, electrical problem Triumph 9
Hamish Racing TR2/3/3A Aintree sprint (uk) home to the British GP Iain 1950’s Triumph 0
R TR6 I just brought this to its new home. It has been stored for 15 years, has only 21000 miles , and only 1000 sincw Triumph 12
AngliaGT Saw This When We Got Home Today Spotted 3
JPSmit Ms Triss is home again. Spridgets 12
drooartz Carried home on my shield... again Spridgets 17
7 General TR Its home! Triumph 7
R The long road home Spridgets 1
Basil TR2/3/3A On my way home from town - spotted this Triumph 9
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
JPSmit Ms. Triss is home! Spridgets 12
Lin A little "Stay-at-Home" Healey Nostalgia Austin Healey 10
AngliaGT Miata - ALMOST Made it Home Other Cars 7
JimLaney For Sale 2 MK IIIs :Free to good Home Spridgets Classified 1
S TR2/3/3A TR3 clutch release bearing... from Home Depot? Triumph 12
Joe Schlosser Wire wheel Parts Free to good home Spridgets 0
Jim_Gruber Drove Bugsy home this AM Spridgets 15
waltesefalcon It's home! Other Cars 9
drooartz MGB Engine on the hoof - parts car comes home MG 8
JPSmit Home from Boarding School! Spridgets 11
RAC68 Home Made Healey Exhaust Headers from a BOX Austin Healey 15
D TR2/3/3A Home Again! Triumph 12
steveg HD8s easily rebuilt at home Austin Healey 4
drooartz Penny the Bugeye in her new home Spridgets 39
wangdango Home-made ducting for BJ8 radiator? Austin Healey 11
R Prepping to bring my 100 home Austin Healey 5
NutmegCT T-Series New home for an old TD MG 30
Jim_Gruber Bugsy II - Left for a new home this morning Spridgets 4
Marla TR4/4A Take the long way home Triumph 11
drooartz MGB An old friend comes home - I have an MGB again MG 27
Keith_M Look what came home Spridgets 14
steveg Odd problem but it got me home! Austin Healey 9
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
JPSmit Ms Triss is coming home today Spridgets 7
Bob McElwee Miss BT has a new home [probably a new name too!] Austin Healey 1
Mickey Richaud T-Series Home, James MG 4
Tinkerman TR2/3/3A Original wind screen 1960 TR3 A [free to a good home] Triumph 2
catfood Saw five iteresting vehicles on the way home last night.. Spotted 3
M Spridget Parts - Free to a Good Home Spridgets 0
JPSmit Ms Triss comes home tonight Spridgets 13
Dave Richards Greetings from a new home in Utah Austin Healey 5
N BEST Home Brew Penetrating Oil Jaguar 5
N BEST Home Brew Penetrating Oil Austin Healey 27
N General Tech BEST Home Brew Penetrating Oil Triumph 14
N BEST Home Brew Penetrating Oil Restoration & Tools 7
TRMark TR4/4A H6 Find a new home or toss Triumph 4
