Spitfire Spitfire starter puzzle
spithuron
I bought my first Spit (78) 3 months ago. It's a project car, doesn't start, primer paint. I bought from an older gentleman who owned it 6 years and according to title only drove it 12 miles. Sat in heated garage most time he owned it. I'm not much of a mechanic, but want to learn.
I cleaned connections, checked battery, starter relay, determined it must be bad starter. Took out, had bench tested and is no good and gear teeth were badly worn. Ordered new one online, rec'd a Remy 16121 with 9 teeth. Noticed old starter, and should have checked this out before ordering, was stamped Lucas 25147 and has 10 teeth. Looking around on nets, I found this # has application for Austins, MG MKII, but could not find an app for Triumph. Does anyone know if some Spits used 10 teeth starter pinions? I wonder if someone assumed any MG starter will work in a Spit. How could I check flywheel to see what it really needs? I'm thinking about installing it and turning starter manually with wrench, but not sure if I'll be able to tell if gears are really meshing turning that slowly. The flywheel is very tight and I can't turn it by hand, but can move it a little with screwdriver. Any advice out there?
Rhodyspit75
I checked Rock Auto and they list that Remy for the Spitfire. I would put it in. My guess is the old one was wrong to begin with. Welcome to the world of Sprifires.
HerronScott
Sounds like someone put the wrong starter in as everything I can find points to 9 teeth for the Spitfire. I think Lucas 25149 would have been a valid number for the Spitfire.
Scott
S
spithuron
I believe the 9 tooth was original equipment, how can I tell if the flywheel has been changed, or what are chances of that?
N Spitfire Spitfire starter ?'s Triumph 3
doates Spitfire Spitfire Starter Solenoid Triumph 2
J Spitfire Starter problem, 78 Spitfire Triumph 15
R Spitfire 67 Spitfire Starter Problems - Help!! Triumph 9
Z Spitfire Spitfire starter Triumph 8
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
