Spitfire Spitfire/Midget transmission questions
twigworker
This is a repeat of a post that I made yesterday over on the Spridgets forum. Good and usefull stuff coming in there, but I still haven't gotten the information that I need to safely remove the speedo drive gear from the out-put shaft. Any first hand experience would be appreciated.
Someone brought a 1500cc gear box to me semi stripped of it's outside stuff and said "fix it". I've been through a number of LBC transmissions but not one of these.
Is there a way to accurately identify which model it came from, Midget or Spitfire?
I have taken most of it apart, but have run into something that I should ask about before I break it.
The speedo drive gear on the output shaft is very reluctant to depart from it's perch on the shaft and with the gear itself being plastic I don't want to break that part trying to drive it off. It looks like it was pressed on without snap rings to locate it.
Any words to the wise as to how to get it off without a disaster?
AND
In looking at this thing I already know that I am going to need a reverse idler and the 1-2 speed gear hub, and possibly the cluster. Moss shows NLS on the cluster and the hub, so I am going to need another vendor on at least those bits. Any suggestions?
Jack
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
U Spitfire Spitfire or Midget Triumph 11
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
K 1275 Midget motor/trans into a 75 Spitfire? Spridgets 3
K T-Series 75 MG Midget motor = 75 Spitfire motor? MG 3
Dug Spitfire Spitfire vs midget wire wheels? Triumph 2
R spitfire OD in MG midget, trany & clutch question Spridgets 4
M Spitfire spitfire 1500 vs MG Midget engine Triumph 8
1976Midget Midget 1500 VS Spitfire 1500 Spridgets 4
frankenstang57 T-Series spitfire vs midget MG 2
frankenstang57 Spitfire mg midget vs spitfire Triumph 7
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
