Rover V8 prices way down.
tr8todd
I went to the local junk yard on Sat to find a piece for my sister's Camry. No Camrys, but three Rovers. I bought a complete running 4.0 out of a '96 Discovery for $300. They will even remove it for me and load it into my truck first thing on Monday. I've been looking for another 4.0 to build a turbo motor out of. This particular version seems ideal. It has the distributor tapings still on the timing cover, but utilized a coil pack arrangement instead of the distributor. It also has the later crank driven oil pump instead of the early cam/distributor driven ones. I've found that the early design wears cam gears at higher rpms. Your asking that gear to turn both the distributor and the oil pump. It also has a low water pump height like the TR8 front cover does. Most of the later truck covers had a water pump height that wouldn't clear the hood when closed. This one should work fine. I'll have the motor built and then decide whether to go with a modern fuel injected turbo or just a simple blow thru set up. My goal is somewhere around 400 HP at the wheels. The car this motor will go into all ready has a 31 spline Ford 8.8 out of a Explorer, and a drive shaft designed for over 500HP.
PATR8
That is awesome, I wold love to find a deal like that around here but Rovers are pretty hard to find around here for any price
Brosky
Todd,
Did they have any Miata seats? If you go back Monday, could you check for me?
Thanks,
Paul
PATR8
I just checked on line at the large Foreign parts place, they have everything on line. $800 for a 3.9 or 4.0. Both with over 130,000 and "running fine when parked"
DNK
This ought to do ya Paul
Seats.
<span style="font-size: 26pt"><span style="color: #FF0000">IGNORE THIS POST</span></span>
T
tr8todd
I didn't notice any Miatas this time, but I wasn't really looking for them. The yard does get them in from time to time. I bought a couple of Miata hard tops from him for my SCCA buddies to use. This yard as well as many others around here are very thin on cars. With the price of scrap so high this past summer, many cars were just crushed. Now that scrap is back around $60 a ton, the yards are filling back up again. The Discovery did have some very nice tan leather seats. I plan on asking about them when I go back to fetch my motor. Don't know if I can make the seat frames fit into a TR, but the leather covers were very clean. They look to be about the same size as a TR7 seat frame. My wife has an industrial sewing machine, so she could most likely restich the covers to fit the TR seats. I'm not sure how many miles were on this truck. All of the dash stuff was missing, so no odometer. The foot pedals showed very little wear, and the interior was not all cluttered up with trash. It did have some drivers side accident damage, so that is probably why it is in the wrecking yard. That plus the fact that they have depreciated to nill and still cost a fortune to fix.
Number_6
Hi TR8Todd, What was the name the junk yard where you got the engine?
DNK
DART said:
Was that the intentional link??? Can't see using those to even hold seats down.
Went to fix my post and the seats where gone.
Sorry Paul!
T
tr8todd
Ferreiras in Carver. I also noticed that they had three different versions of straight6 and V12 fuel injected Jags. Just about all of the yards around here have Rovers thou. Most are of the 3.5,3.9,4.2 variant. 4.0s tend to run around $800, but I haven't seen any sell at that price lately. Have'nt seen any 4.6s yet. Henrys in Blackstone had 3 Rovers in the pick and pull section last time I went in there. They also had a complete 3.9 motor on a shelf for $250, and a couple of later complete Rovers in the section you were not allowed into. In that section, you tell them the part you need- they quote a price and remove the part for you. They quoted me $800 for a complete running, garuanteed for a month, 4.0, with wiring and the computer.
T
tr8todd
Picked up my engine today. Yesterday was just too cold. I ended up spending some time unbolting the engine. I just wanted to make sure nothing was broken by the heavy handed yard attendant. He was a real animal. Instead of proping up the front end, so I could get at the bolts under the truck, he just rolled the truck onto it's side. He also used the forks of the loader to pick the truck up by it's roof. He blew thru two side windows and lifted it right up. Here I was trying not to damage anything I wasn't taking, and he just crushed perfect body panels. Once we got the motor out, he said I could take anything else I wanted. He said he was done with it and was going to crush it. It still had a nice interior, and a complete driveline minus the motor. The front brakes looked almost new on it. I grabbed the starter, some brackets and crossmembers, some heat sleeves, and as much wiring as I could get to. It was getting dark or I would have grabbed the two electric fans on the AC condensor. All in all, not a bad $300 spent. I left behind the PS pump and the AC stuff, but I took everthing else that was bolted to the engine. This weekend I'll strip it down and get it ready to go to the machine shop.
PATR8
wow, good deal there. The yards around here are building up their stock again after scrapping so much when it was way up. Th all foreign parts in PGH is the best place ever, all cars are under cover in an old steel mill. a pretty prefessional team removing all the engines which come with all you need to run it (ECU ect) but it comes at a price
Brosky
How hard would it be to put one of those Rover V-8's into a TR6?
PATR8
Not to mention the great sound
EMGEBE aussie rover v8, .....help!!!.... PRICES???? Rover / Land Rover 2
J Land Rover research Rover / Land Rover 4
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
F For Sale Rover V8 blocks for sale Other British Classifieds 1
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
CJRams For Sale 1996 Rover MGF 1.8i - $15,000 MG Classifieds 3
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
A For Sale Supercharger setup complete for Rover V8 3.9/4.0/4.2 Other British Classifieds 3
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
D Land Rover engine swop. Rover / Land Rover 1
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
A MGB Donor Rover 3500 P6B for my MGB MG 5
albertemore Range Rover Classic Parts? Rover / Land Rover 5
G Rover P3 Brake Lining - Front Rover / Land Rover 2
hutten Wheel sizes for Rover Mini Mark VII British Motor Corp 1
PAUL161 Land Rover 73 Rover / Land Rover 0
Z MGB My 5.8 OHC Rover V8 build yes this is a P76 block from do under! MG 10
Steve Range Rover Evoque Convertible Rover / Land Rover 2
LarryK Land Rover Repair or just plain how to! Rover / Land Rover 1
catfood Land Rover Evoque Convertible Spotted 1
aeronca65t Landwind - fake Rover Rover / Land Rover 3
Steve Land Rover 90 vs. Dodge Ram Rover / Land Rover 1
Boink First Range Rover Rover / Land Rover 2
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
K Land Rover Defender - Mountain Rescue Team Rover / Land Rover 0
N Land rover and coffman cartridge starter Rover / Land Rover 0
HealeyRick A Visit to the Land Rover Factory Rover / Land Rover 0
B Rover V-8 main bearings Rover / Land Rover 5
G Rover 3.9 info?? Rover / Land Rover 1
JPSmit Land Rover Defender - and Home made special Spotted 1
aeronca65t Rover car carrier Rover / Land Rover 1
JPSmit Land Rover - hopefully good news. Spotted 9
M T16 engine, ecu and two key fobs, or Rover 820 Rover / Land Rover 0
aeronca65t Churchill's Land Rover For Sale Rover / Land Rover 1
aseriesspares LAND ROVER SERIES 3 Complete Hardware Sets 30% OFF Rover / Land Rover 0
Steve New Land Rover Defender Rover / Land Rover 9
58Custom Rover V8 in SoCal self-serve junkyard Rover / Land Rover 0
G Rover V8 interchange/swap question MG 9
rosalind Bye Old Rover...Hello new Rover Rover / Land Rover 2
aeronca65t Land Rover Forward Control Rover / Land Rover 0
T What car could use a Rover V8 Other Cars 3
Got_All_4 Wedge Rover 3.9 in a Tr7 Triumph 34
Steve Range Rover Evoque Rover / Land Rover 1
AngliaGT Rover 3500 Rover / Land Rover 1
M 2000 range rover????? Other British Cars 1
D 1935 Rover 10 wiring dia. and head lamp solonoid.. Rover / Land Rover 2
weewillie rover p6 and nissan skyline Spotted 0
racingenglishcars Land Rover collection for sale - in Norway, Dec 4 Rover / Land Rover 0
S Looking for a Rover 215 motor. MG 9
