Got_All_4
9k miles ago after the rebuild I had to adjust the rockers again because of valve train noise. The first time was at 5k. I have a reground cam with new tappets. Did the proper brake in with Isky grease and added TSI roller rockers 155:1 with an auxiliary oil line. Now hear is what I think the problem is and see what you guys think.
The first adjustment I noticed that the rockers were just slightly loose on the shaft (the bushings) and attributed it to brake in and made a mental note. Now 4k later I had some noticeable noise and was really concerned. Took some measurements first and some gaps were fine and most were 9k" to 12k" over. Some of the rockers may be looser then the first adjustment but #2 can be rock from side to side and when I put a wrench on it to tighten the jam nut down it made a noticeable twist.
Has there been a quality issue with these roller rockers? I did add that oil line for extra oiling and peace of mind. But the bushings are brass or bronze and are softer then the shaft. The head and the block were thoroughly cleaned by the machine shop that did the machining work. I remember blowing the ports out too during assembly so I'm quite confident there are no plugged ports.
What do you think???
