jlaird
Is the tac gearbox only supose to have oil in it?
What DOT is the brake fluid that does not eat paint? Any down sides? With all new cylinders will I have probs with seals etc?
I found an 1100 exhaust manifold that looks much like the 1275, not with the strange plate on the top like the 948 one but uses the 948 exhaust system. ie no plate to exhaust pipe. 10$, still have not decided which one I am going to use but have a choice.
Next week I am going to try to put a new choke cable on a heater switch. Seems doable but maybe I will screw it up, Hehe. Oh well, no choke cable now so. At least the electric switch works.
Now have all the bits for the windsheld washer pump and mounting. Also all the bits for the mounting for the turn signal light and such behind the dash. The remaining switches and such I can get new.
Have a nasty old steering wheel now that I am going to clean good and give a coat or so of plastic paint. Will use this till I get to the interior and spring for a nice new one, wooden, etc.
Painted up my new rebuilt master cylinder, looks nice and I bet works correctly. Will be quite a few till I get to that but one less job.
Nice soft car cover came yesterday. I will protect my paint etc., etc., from day one even inside.
Rained a bit here last nite, first time in three months, hot and humid, not nice at all outside. In my next life I am going to have an air conditioned garage and workshop.
Can you tell it is now too hot to be outside and it is only 9:30. However I have accomplished quite a bit since I returned from North Alabama even if it has only been small bits. Got to be ready to start assembling when Miss Agatha comes home. Would be a real pain to have to stop a stem and clean something up or wait on paint to dry. I know I will be waiting on parts for ever as I will only order in easy stages as I need for assembly, got to keep wife happy you know.
Cheers /ubbthreads/images/graemlins/savewave.gif
