Proper length for sprite front shock arm
djk
I'm making progress on my restoration; got the engine and tranny in, and then lowered the car to make it a roller. When the car came down, we noticed that there was a severe inward tilt on the front wheels, so the bugeye looks cross-eyed! Someone suggested that my front shocks are from a later model, and might not be the right size. Can someone with a bugeye measure the distance between the upper fulcrum pin and the middle of the crown nut attached to the shock body? If it turns out the shocks are right, do you have any idea as to why my wheels are tilted? The top of the front wheel is leaning out and the bottom of the wheel is in more. Picture cartoon slitted cat eyes.
Thanks!
-Debra
Morris
Debra,
You, like all of us at one time or another, have put your upper trunnions on backwards. Welcome to the club!
Turn the trunnion around 180 degrees. Common mistake and an easy fix. Most all of us have done it at least once.
Photo finish!
PeterC
Yep. Had a guy trailer his car 50 miles to show me I sold him the wrong parts.
I bought him a beer for his troubles. He just couldn't "see" it.
Peter C.
jlaird
Hmmmm, the Backward Trunon Club. I'm a member as well.
What did I miss here? Who is dkj, I know west coast, and Debra.
Do tell, she is doing her own work? Outstanding.
Tried to look her up in the new members area but had no luck.
Welcome, welcome.
She is the one that rolled her sprite and is rebuilding it. She has a blog somewhere.
jlaird
Know nothing about Blogs but that link has a prob.
It is working for me.
It takes a few minutes to load, but it works. I think the server that it is on experiencing high loads for some reason.
bugimike
Thanks, you are right it just took some patience!! Pretty cool!!
jlaird
Boy, is slow. Looks like fun stuff to me.
djk
djk
Yep, I'm Debra in San Francisco, who's rebuilding the bugeye. I am getting help from the great Healey community, but a lot of the work is solo. Needless to say, I'm always extremely overwhelmed but enjoying myself and learning a ton.
I'll look into my service to see why my blog is loading so slowly. I've just updated it today with photos from last weekend's work.
https://www.flickr.com/photos/brokenroads/sets/72157604102609160/
Next on my list of things to do: wiring, the brightwork, cleaning up the carbs and generator, getting the exhaust header fit and welded, and of course, reversing the trunion caps!
Thanks for the help and advice, and for following my progress. I'm pushing hard to be done by the end of April.
jlaird
And it looks like it is comming along well. You/someone is doing nice work.
V
vagt6
Debra, nice work on the car!
Don't feel "overwhelmed" when you get stumped by a trunnion or similar. Most of us here are not, and have not been professional mechanics and have learned on the fly.
It seems you are enjoying the journey, possibly the most important part of this hobby.
Good luck to you, keep posting your progress!
R TR6 Proper alignment of gearbox front cover plate Triumph 3
sundown TR6 Proper ring gaps Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred Proper attachment of Demister tubes and vents Spridgets 3
M Proper running temp for 1275 Spridgets 28
Bob_Spidell Proper Engagement of Overdrive Austin Healey 8
M Hauling a Spridget - Proper tie down technique? Spridgets 15
M Proper oil? Spridgets 6
Got_All_4 TR2/3/3A Which oil cap decal is proper to use with this cap Triumph 7
M What is the proper oil for Bugeye engne and transmission Spridgets 6
M Choosing the proper inner tube Spridgets 6
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
KVH TR4/4A Proper Ring Gap Triumph 4
bugedd Fuel Leak and Proper Routing Spridgets 9
M '69 Sprite Proper Seats Spridgets 3
R Proper Timing Technique '60 BN7 Austin Healey 0
bighealeysource Proper way to "seat" ball bearings in OD operating valve Austin Healey 3
britlover proper tire size to replace 5.90-15? Austin Healey 16
Got_All_4 TR2/3/3A Is this the proper Boot lid seal? Triumph 9
K TR2/3/3A Proper size of "set screw/bolt?" for top of trans..... Triumph 1
J TR2/3/3A Proper distributor for 1960 TR 3A Triumph 5
K Proper SU Adustment Austin Healey 16
T proper jump starting technique Austin Healey 2
F Proper location of chrome loop for spare tire strap? Austin Healey 2
M Proper torque for cylinder head nuts Triumph 20
R proper antifreeze? Spridgets 2
B MGB Proper MGB Overdrive speedometer MG 3
A Proper Gear oil? Triumph 9
brgrmyster Proper finish on luggage floor angle assembly? Triumph 0
M Restoring proper order to spark plug wires Triumph 36
M Proper use of the Gunson Colortune Triumph 41
brgrmyster GT6 Proper stock color oil filter canister 68 GT6? Triumph 7
G Proper Torque for Water Pump Install MG 4
tri_carb_healey brake drum work, proper jack points Austin Healey 12
tri_carb_healey proper type of gasoline Austin Healey 6
bighealeysource Pics needed on proper way to fold up top on BN2 Austin Healey 1
M Proper Brake Fluid For 1960 Morris Minor Pick Up Spridgets 8
J Proper brake fluid Austin Healey 19
af3683 TR2/3/3A Proper Use of Jack Stands on Rear of TR3B Triumph 9
M Proper servicing of overdrive Triumph 15
M Proper use of British Crimping tool Triumph 21
af3683 TR2/3/3A Proper Oil for TR-3 Steering Box Triumph 22
M TR2/3/3A Proper servicing of TR3 air filters Triumph 20
T proper use of exhaust clamps Austin Healey 11
rggav Proper way to remove and reinstall wire wheels? MG 6
pjsmetana Spitfire Proper Jack Points? Spitfire Triumph 8
H Proper Installation of shock mounting plate Austin Healey 3
P TR2/3/3A Proper screws for a TR3A interior Triumph 4
A Proper Oil Filter MG 22
6 Whats the Proper Way to Remove Tie rods on AH BJ8? Austin Healey 17
