Keoke
[ QUOTE ]
I worked the screwdriver all the way around the neck of the rad. Hose is on the neck at least an inch - inch and a half. It's now dripping from the top end of the hose because I loosened both clamps, thinking this was going to be easy. At the current rate of drippage, I should be able to finish up about May 17th.
[/ QUOTE ]
HI Jaybird, I see you say you loosened the clamps.Perhaps the one at the hose end you are trying to remove has not been loosened enough.loosen it enough to slide it down the hose and repeat the screwdriver all around the neck bit once more and see if it does not come off.--Fwiw--Keoke
[/ QUOTE ]
