MG fuel pumps.
Crisis
Just visiting from the Triumph page as I had a question regarding MG's. Did all MG's (B's & Midgets) come with electric fuel pumps, or were there ever any mechanical units?
Thanks for any information.
tony barnhill
Great Pumpkin - R.I.P
My '63 Midget has a mechanical fuel pump.
Steve_S
<span style="text-decoration: line-through">I can't say 100% for sure on the late models, but anything with chrome bumpers is mechanical.</span>
EDIT: I misunderstood the question. See post below.
PeterC
All Bs and As were electric pumps. Midgets were mechanical for 948s, then electric for 1098 and 1275, then back to mechanical on Triumph powered 1500s in 1975.
Peter C
tony barnhill
PeterC...you're correct..except I have a '63 w/1098 & mechanical pump (& the car never had an electric pump!).
Um....both of my MGCs have SU fuel pumps.
vping
Bronze
Wuz gonna say the same thing. All my 67's and all the 74's I had are Electric. For that matter, so is my 1952 TD.
All the 1275 Midget and Sprite cars I had all were electric.
ronzet
My two cents...
I have had many As and Bs (pre68) and have never found a mechanical pump... they have all been 'lectric...
Platinum
Look at th' 'rumphs.
Them fellas have AC mechanicals.
David_DuBois
All MGs, with the exception of the afore mentioned Midgets and some of the pre war racing models (which used pressurized fuel tanks - pressurized by the riding mechanic pumping pressure into the tank with a hand pump) had electric fuel pumps. Not all of the electric pumps were SU. Some of th every first models used what was called a petrol lift pump of unknown manufacture.
Cheers
Steve_S said:
HOLD THE PRESS!!! I thought we were talking points-type SU pumps versus electronic SU pumps. I've edited my post.
Well.....OK...... :angel:
ronzet
Ya' know tho'...
There appears to be a hole, normally covered by a plate, on the block below the manifolds that has all the earmarks of a mechanical fuel pump mount... I have never taken the time to see if there is a subsequent lobe on the cam.
Maybe it was a 'just in case we decide to add one later' by the MG engineers... :smirk:
Roger
Bronze
ronzet said:
Ya' know tho'...
Remember that was a generic BMC block with a gazillion applications, some of which used mechanical pumps.
Joe Reed
You're right - that is a fuel pump blanking plate. The B series was used in a number of other vehicles, and some used mechanical fuel pumps.
ronzet
Roger and Joe,
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Remember that was a generic BMC block with a gazillion applications, some of which used mechanical pumps. [/QUOTE]
Well now, that explains it... :thumbsup:
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
PAUL161 T-Series Fuel Pumps MG 5
T Rebuild kit for fuel pumps 1955 to 1964 Spridgets 1
S TR2/3/3A Not all tr3 fuel pumps are built the same Triumph 5
bugedd Two fuel pumps Spridgets 4
K TR2/3/3A Fuel pumps and Neg/Pos ground? Triumph 6
drooartz MGB-GT Facet vs SU fuel pumps MG 18
K TR2/3/3A More on Fuel Pumps..... Triumph 6
oxford fuel pumps Austin Healey 3
coj Alternative fuel pumps Austin Healey 19
coj fuel pumps AH 3000 BT Austin Healey 9
M TR2/3/3A fuel pumps from Turkey Triumph 5
5 Modern [Burlen] SU fuel pumps Austin Healey 7
G Where you 6 guys putting fuel pumps? Triumph 10
H QH brand fuel pumps MG 2
T More on mechanical fuel pumps Triumph 32
Michael Oritt Who repairs SU fuel pumps? Austin Healey 7
livinginthepast Work, missed events, bad fuel pumps, radiator, etc Spridgets 1
T What do you think about these fuel pumps? Triumph 5
M Do 1098 motors have fuel pumps ? Spridgets 8
T AC Electric fuel pumps - time for some schooling.. Triumph 10
T fuel pumps and shocks Spridgets 12
sparkydave Facet fuel pumps reliable? Spridgets 23
Jim_Gruber Mr. Gasket Fuel Pumps Spridgets 9
Luke_Healey Non stock fuel pumps? Spridgets 5
L Electric fuel pumps Lotus 10
T Spitfire Spitfire fuel pumps Triumph 6
philman fuel pumps for '76 B MG 3
John Moore Spridget 1275 SU Fuel Pumps Spridgets 11
ronzet Fuel pumps, generators, and leaking SUs MG 10
mrv8q Fun w/ Fuel Pumps Triumph 8
Brit_Brother How often do you check your SU fuel pumps ? Austin Healey 25
71tr fuel pumps Triumph 15
T fuel pumps for webers Triumph 14
R SU Fuel pumps Austin Healey 3
B Fuel Pumps Austin Healey 2
R Alternative Fuel Pumps for a 420 Jaguar 10
S TR2/3/3A Tr3 fuel pumps in the mountains. Triumph 11
RichC SU Fuel Pumps: diagnosing? MG 9
WALTER mechanical fuel pumps Spridgets 12
bighly Whack that pump [ Fuel Pumps ] Austin Healey 3
J electric fuel pumps Austin Healey 9
F Fuel pumps Spridgets 6
AndreL TR6 Conversion to electric fuel pump Triumph 13
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
