I think they'll be okay. This will be snug in the back of the pickup and I've since wrapped the engine in that shipping plastic wrap to keep it all snug.Looks impressive. (Is it worth removing the fan - plastic blades are vulnerable - don't ask me how I know)
I was chuckling about this myself. It's on a beat up pallet from work with some scrap OSB screwed down on top for support. The 2x4 was also scrap, quite warped and purchased back when lumber was cheap.Looks like you used about $1000 worth of wood
on that engine support.
Good to see you making progress! The MGB gets driven almost every day, weather permitting and the kids love it! Clutch slave started leaking last week and I ordered a new one from Moss along with a rebuild kit. The threads were buggered up on the new one, so I used 1000 grit to clean up the bore on the old one and she’s back in business. They use it, I fix it...Got the engine and transmissions all packed up and ready for hauling down to AZ for the rebuild. Transmissions you say? I happen to have two OD transmissions, the original from the car and a spare I picked up from a parts car. I'm bringing them both down so that they can use the best one as a base for a rebuild (or for parts if necessary). I've got a couple spare blocks as well, but hoping that the original one won't have issues and will be fully rebuildable.
Sounds like you're gonna have a new car!
Great looking shop - must be a delight to work there.
Two spares, actually. I would like to do a refresh on one of them some day, would be a fun learning experience. I've actually got replacement bearings for one of them (same size) as I was planning on a simple refresh before I decided to go all out. It's certainly on the list, but the Bugeye comes first.ISTR you've a spare engine. Any intent to go thru that at some point? It could be at a leisurely pace, a kind of "journey of discovery" for you.
Me too. I'll post up what I find out once it comes in.Would like to see the machine shop report regarding the block condition….I am curious about the cylinder measure.
Cylinder #3?First bit of news back from the shop. Small crack in the head, machine shop feels it's an easy fix. I have other heads, but there's no guarantee they're any better so going to try the repair and see how it goes.
