MGB Made a decision, my MGB is going...
AngliaGT
Looks like you used about $1000 worth of wood
on that engine support.
drooartz
drooartz
Looks impressive. (Is it worth removing the fan - plastic blades are vulnerable - don't ask me how I know)
I think they'll be okay. This will be snug in the back of the pickup and I've since wrapped the engine in that shipping plastic wrap to keep it all snug.
drooartz
drooartz
I was chuckling about this myself. It's on a beat up pallet from work with some scrap OSB screwed down on top for support. The 2x4 was also scrap, quite warped and purchased back when lumber was cheap.
I was very careful with my measurements, however, as I certainly didn't want to buy any more wood!
Rut
Got the engine and transmissions all packed up and ready for hauling down to AZ for the rebuild. Transmissions you say? I happen to have two OD transmissions, the original from the car and a spare I picked up from a parts car. I'm bringing them both down so that they can use the best one as a base for a rebuild (or for parts if necessary). I've got a couple spare blocks as well, but hoping that the original one won't have issues and will be fully rebuildable.
Good to see you making progress! The MGB gets driven almost every day, weather permitting and the kids love it! Clutch slave started leaking last week and I ordered a new one from Moss along with a rebuild kit. The threads were buggered up on the new one, so I used 1000 grit to clean up the bore on the old one and she’s back in business. They use it, I fix it...
Rut
drooartz
drooartz
Made the trip from UT to AZ last weekend, safely delivering the car to the shop for work. Borrowed my FIL's nice F150, traveling in style! My friend and I co-own the trailer -- we both own old British cars so it's handy to have. ;)
The shop was working on some really nice stuff, ranging from a MG TD to a TR3 to an AC Aceca and an Aston DB2/4. I think my little B is in good hands.
About 45 mins from my house, Mt Timpanogos in the background
Lake Powell (Glen Canyon Dam near Page AZ)
The shop
My B, off the trailer and waiting her turn
drooartz
drooartz
The main work I'm having them do is a full engine rebuild and possibly a transmission rebuild as well. They're at least going to open up the box and see what it needs. I happen to have a spare as well (both OD) so I dropped off both in case my original one is too far gone.
Today I got the results of their initial inspection of the car for any other issues. I asked them to look it over and see what else is needed. The list they sent me contained no surprises, just the usual seals/brakes/hoses/worn out bits. I did chuckle as some of this is replacing parts, like the brake/clutch hoses and tires, that have aged out since I installed them 10 years ago when I first bought the car. I guess I've been doing this long enough now to need to redo my own work... :oops:
So here's the initial list. I'm going to have them sort it all out, and get me a quote for the minor bodywork (door skins, repaint engine bay and inside the boot). I'm not sure the bodywork will be in my budget, but it's worth finding out. The rest of it is usual wear, and I'm perfectly happy to have them sort it out so I can be driving all that much sooner.
  • Rear spring bushings are expired
  • Axle case gasket and pinion seal
  • Change rear shock fluid
  • Axle service
  • Axle retaining straps
  • E-brake system needs cleaned and lubed or to be replaced
  • All fuel hoses going to and from fuel pump
  • Recommend power washing of undercarriage
  • All brake and clutch soft lines
  • Need rear brakes
  • Tires from 2010
  • Fuel filler neck
  • Passenger door mirror? We can get a quote for you on patching the old mirror holes if you would like
  • Bonnet prop rod holder
  • Wiring in engine bay is disarray
  • Steering rack has a few leaks
  • Oil pressure braided line
  • Heater valve pull cord
  • Fuel filter
  • Brake master
  • No battery
  • Horns are very faint
Mickey Richaud
Sounds like you're gonna have a new car!
Great looking shop - must be a delight to work there.
drooartz
drooartz
Probably going to cost as much as a new car as well! :oops: No regrets, though. I'm happy to "buy" this car again and get out and drive it.
Platinum
Shop looks to be a class act, Drew. Good choice.
We'll be interested to learn of progress.
drooartz
drooartz
I'll keep y'all posted. This is going to be a fun adventure. It almost feels like I'm buying this car for a third time, just as exciting to think about driving it again.
drooartz
drooartz
Here's the update for this week (the shop sends a weekly update on Friday).
They have received parts for the list of work to do, and the engine is torn down and at the machine shop. We're waiting to hear back from the machine shop on details so we can make a plan for the rebuild.
drooartz
drooartz
June update from the shop (image as they sent me a PDF for the June bill). In short, all is disassembled and cataloged. Looks like I made a good call to rebuild this engine instead of keeping on driving it. Seized piston rings, worn bearings, but cylinder walls and block look OK. Also nice is that the transmission seems to be in good shape -- it was shifting fine before, but I figured we'd go through it with everything out. May be a nice savings if it just needs a looksie and servicing.
I like the detail they're giving me. My friend had similar work done by this shop and he received the same level of detail, so I was expecting it. Still, it's nice to see a clear record of what they're doing. Makes it a bit more pleasant to pay the bill.
Platinum
That's great, Drew! Seems as if you're in good hands.
The report is a bit more verbose than we'd do but finding a shop that does it at all is rare. Ours were terse by comparison. We also shot many photos as things progressed, I would guess they're doing the same.
drooartz
drooartz
Does make me feel confident for sure. Now comes the interesting part as we fix what's broken and put it all back together.
Platinum
ISTR you've a spare engine. Any intent to go thru that at some point? It could be at a leisurely pace, a kind of "journey of discovery" for you.
Grantura_MKI
Would like to see the machine shop report regarding the block condition….I am curious about the cylinder measure.
drooartz
drooartz
Two spares, actually. I would like to do a refresh on one of them some day, would be a fun learning experience. I've actually got replacement bearings for one of them (same size) as I was planning on a simple refresh before I decided to go all out. It's certainly on the list, but the Bugeye comes first.
Me too. I'll post up what I find out once it comes in.
drooartz
drooartz
First bit of news back from the shop. Small crack in the head, machine shop feels it's an easy fix. I have other heads, but there's no guarantee they're any better so going to try the repair and see how it goes.
Platinum
Cylinder #3?
Pythias Made the decision to sell. Spridgets 6
drooartz Engine decision made, gonna be a fun winter! Spridgets 21
drooartz A decision made for more power Spridgets 24
Randy Harris Having made the fateful decision.. Jaguar 0
C TR6 Work Continues. Proggress being made Triumph 6
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
D Made a sheet metal break. Restoration & Tools 5
JPSmit Made me chuckle. Spridgets 13
tr6nitjulius TR6 TR6 made another list! Triumph 5
M I made some embroidered Austin-Healey Hats if interested Austin Healey 4
AngliaGT Miata - ALMOST Made it Home Other Cars 7
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
S TR2/3/3A What's a little thing that made a huge difference in your vehicle? Triumph 37
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
RAC68 Home Made Healey Exhaust Headers from a BOX Austin Healey 15
Boink Made it into the AHCA club calendar... Spridgets 5
wangdango Home-made ducting for BJ8 radiator? Austin Healey 11
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
M TR2/3/3A What is my radiator made of? Brass? Triumph 6
doc50 TR2/3/3A So I Made My Own Triumph 5
JPSmit Daughter made a video Spridgets 18
S This internet article/post made me laugh... Austin Healey 5
J Made a lot of sawdust today, brought back a lot of memories Restoration & Tools 6
Jim_Gruber Actually made some progress on Bugsy II Today Spridgets 4
Boink Last Midget Made Spridgets 10
60TR3A Had a Portrait Made of My Car Austin Healey 9
T TR2/3/3A We made it -TR3 first trip Triumph 20
oxford Look what I made Dad! Austin Healey 3
B MGB well made sebring valance MG 3
Boggsy64 MGB Made it 2200miles and 22 quarts of oil later! MG 7
JPSmit Land Rover Defender - and Home made special Spotted 1
DanLewis Taking a chance on a Chinese-made aluminum radiator for my Bugeye Spridgets 74
sjuengst Spitfire Handmade toy Spitfire made in the Congo. Triumph 2
hilsideser Spitfire Spitfire also made this list... Triumph 0
HealeyRick 1500 Engine Rebuild Made Easy Spridgets 5
sd80mac7204 Think I made a mistake Triumph 4
Xte TIPS : Home made tool for the thermal sensor Austin Healey 7
C Made to be raced! Austin Healey 11
JPSmit Home made axle puller Restoration & Tools 5
G Midget Cobra? Who made this? Spridgets 19
M_Pied_Lourd Banjo Made Me Do It........ Triumph 11
Banjo If someone made ma a good offer... Triumph 45
rlich8 Today, my day was made! Triumph 27
S This made me smile....... Spotted 6
D i made a stupid mistake. best course of action? Triumph 35
K seats made for triumph replacement good $ Triumph 12
John_Mc It's made of WHAT?! Triumph 13
M No progress being made Triumph 20
RickB Well my Midget made it home... Need Help! Spridgets 80
