jvandyke
Thanks to all for helping me through my clutch issues last week. No longer have grind going into 1st or reverse. Only issue remaining is a little glitch/grind going into 4th. Not sure I can do anything about it, could be inherent in this used gearbox but thought I'd ask anyway, if there's something to be done that can save the gear I'll do it, otherwise I'll run it until it's fried while I rebuild the box I took out.
I tried hesitating a second as I go from 3rd to 4th, even tried double clutching (which I've never done before so I stink at it) but no matter what I get a definite little "grind" as I hit 4th. Maybe that synchro is going out? Looked fine on the bench but that doesn't mean much.
