Well, I guess it's true what they say about pulling a midget engine out in a couple of hours! For me, it took about six. Four hours in the late morning, and the engine was hooked up ready to pull. Break for lunch, and another two hours of engine-wrangling in the afternoon. Many lessons learned today, but first some pics.
Picking up from yesterday, I pulled the front u-joint bolts, and yes, it IS easier from the topside!
I discovered what that little round holes behind the fascia slots in a 1500 are for: Getting to the lower radiator bolts!
Grills and radiator out in 20 minutes, hoses attached. Aren't these cars amazing? (With a couple exceptions, which I'll point out later...)
The First Sign of the Apocylpse: shiny metal bits sticking to the tranny drain plug.
The Second Sign of the Apocylpse: uhmm, transmission fluid isn't supposed to be a silver slurry, is it...?
Answering the Big Question: yes, it does fit. Barely. The legs skim the inside of the front tires, and it needs to be jacked up just a couple inches for the legs to clear the stabilizer bar. (Actually, with the bar unbolted from the A-arms, it might fit, but I didn't try that.)
Ready for action, four hours in...
...and this was as far as it got before the u-joint flange got caught on the crossmember. Argh!
An idea that didn't work: a sling under the flange to try to help it over. Yeah, if I was a gorilla. Luckily the bro had a hydraulic jack; putting that under the tranny gave the inch lift it needed to clear.
Ahh, free and clear in all its bluey...blueness. I don't know why. Maybe the PO liked Fords.
I couldn't help a little preliminary peek. Reverse is a little chipped, the synchro teeth aren't really sharp...hey, is this gear supposed to wobble around a half-inch? No, I didn't think so.
Enough fun for one day. Bits under the house with the engine. Tomorrow I'll try to separate engine from trans and start cleaning stuff off.
Nigel snoozing under cover. But which way is forward?
<span style="color: #6633FF">For posterity, here's a list of the things needed to pull the engine in a 1500, in order. Numbered baggies make a great way to store bolty bits.
1. Bonnet prop. 1 bolt, baggie 1.
2. Bonnet. 4 bolts, baggie 2.
3. Shift gaiter. 4 screws, baggie 3.
4. Shifer anti-rattle plug and spring. Baggie 4.
5. Rear driveshaft. 4 bolts, baggie 5.
6. Heater duct.
7. Front driveshaft. 4 bolts, baggie 6.
8.Grills. 6 screws, baggie 7.
9. Radiator. 4 bolts, 2 screws, baggie 8.
10.Overflow tank (pulls out)
11. Heater hose connections at back of engine.
12. Bourdon tube connection.
13. Alternator connection.
14. Starter wire.
15. Oil pressure connection.
16. Coil wire. *don't forget the low tension wires too!
17. Throttle cable.
18. Fuel line at carb.
19. Engine ground strap at steering rack.
20. Exhaust pipe from manifold. 3 bolts, baggie 9.
21. Clutch slave. 1 bolt, baggie 10.
22. Drain tranny.
23. Drain engine.
24. Transmission mount under crossmember. 2 bolts, baggie 11.
25. Transmission mount on tunnel. 2 bolts, baggie 12.
26. Unplug backup light at shifter.
27. Speedo connection. 1 bolt and plate, baggie 13.
28. "Transmission retaining cable."
29. Fan blade. 4 bolts, baggie 14.
30. Engine mounts. 6 nuts, 2 bolts, baggie 15.</span>
<span style="color: #FF6600">What I learned today:
--There is a cable, a whopping thick one, that connects the lower bellhousing to the crossmember. It apparently serves no other function than complicating pulling the engine. As it was only on USA cars, and no manual seems to mention it, it was apparently a practical joke on the part of the BL engineers. Well, ha ha, chaps.
--Getting the u-joint flange over the crossmember when the engine is tilted is a royal PITA. I would have saved 30 minutes and could have easily done this single-handed if it wasn't for this. Overdrive or not, I'm seriously considering cutting out the center crossmember and reinforcing it lower down just 'cause I'm so ticked at it.
--You cannot pull the clutch slave cylinder without rotating it so the fluid line is about 30 degrees inboard. Actually, I learned this again, as I first learned it a year ago when I replaced the silly thing.
--When the engine is hanging naturally from just the front hoist mount, it assumes the right angle to get it out. This led me to think if this is the ideal way to pull the engine with the hoist and a tilt-lift: To lock it horizontal, swing it forward until the flange clears the crossmember, unlock it, and lift up. The engine will nose-up naturally and clear the front of the car. Swing the tail of the tranny up, lock it horizontal again, and pull it forward.
--The fuel hardline is attached by a little clamp at the top of the transmission. So you have to undo the line down below the car. This siphons the gas out of the tank. (Ha ha BL engineers--got me again!) Be sure to put a little cap over this line.</span>
So the plan for tomorrow is to break the tranny loose, start cleaning, and see what there is to see...
