I've lost second gear!!
Don't wait too long with that rubber band... it begins melting rather quickly! :wink:
More work this morning...the shafts and all the spinny bits got installed in the box.
Unfortunately, my camera phone has decided it doesn't want to communicate right now. Lots of pics and no way to get them here. (yet)
When I can get the pics to load, I'll go back and edit this post with the goodies.
<span style="color: #FF0000"><edit></span>
Next morning...all the slidey bits are installed, and the tranny is all buttoned up. Loads more pics, and a few tricks I learned too. But, the camera is still uncooperative, so those pics will have to wait for now. :cry:
Well, it's the day after, and even though it's reeeally cold, it's not raining. Good enough to make some progress. Got the engine and trans bolted together, and the engine in the car. Yay! Everything underneath is hooked up, so tomorrow (another cold and clear day) everything up top gets plugged in. Hopefully on the road by Tuesday.
It looks like my pics of the last few days are trapped in my phone. (My Pocket MSN is not loading anymore, probably a result of MSN updating their homepage...so I can't email them out)
I didn't take any pics of the installation process, feeling it was a waste of time with no way to get the pics here. I really wanted to do a step-by-step of the intallation, but it'll haveta wait 'till the next time the engine comes out.
Wow, you don't play around do you? I have my ribcase sitting by the door waiting to be taken downstairs. Maybe I'll do a step by step photo deal with that like you did.
Cool! I'd like to see the differences between a ribcase and a 1500.
Step by step of it being taken downstairs?? Sounds pretty boring! :jester:
Unless he trips :devilgrin:
Or the wife catches me or both.
Bill, you have a PM
Well, this odyssey is just about at an end. Put the carpet and seats back in this morning before it started raining, and cranked 'er over. Wouldn't idle or rev, and seemed to be choking out and backfiring. I bet I knocked the distributor a little getting the engine out, and the spark is too retarded. I'll push the spark up and see if that fixes it tomorrow when the rain lets up. It's supposed to be sunny and in the 60's here tomorrow...with luck I'll be driving top-down to work! :driving:
Yep, the dizzy got knocked. Running sweetly now. And the tranny sounds much more solid and smooth. None of that ball-bearings-in-a-soup-can sound that was being caused by that mangled front bearing.
In other news...
Hooray! I finally got a way to connect my phone to the internet, so I can upload pics. I really felt like this little project was missing a sense of closure without posting anything. Besides, I learned some really helpful tricks to re-assembly, that apparently aren't in the books.
Continuing where we left off...
Looking through the empty box to the front end. The big hole is for the input shaft bearing, the hole below it is for the layshaft. The three smaller holes are for the preload springs, which go in from the outside, and the small hole at the bottom is where the belhousing bolt goes through. (That's the bolt with the brass washer.)
These are the brass laygear thrust washers. Notice they have a little tab to hold them in place. (The larger one goes at the front.) Use a little squirt of multi-purpose grease to stick 'em in place.
Looking through the reverse idler gear hole to the front washer, stuck in place with its tab in the corresponding notch at the 12:00 position.
Carefully lower the laygear to the bottom of the box.
The reverse idler fork sits on a pin that sticks through the side of the box. It just presses on.
Hold the reverse idler in position with the fork in the groove...then slide its shaft in from the outside. (My finger is taking the place of the shaft in this pic)
There's a hole in one end of the idler shaft. A bolt comes in from the side of the box to hold the shaft in position. (It's advantagous to peek thru the hole and twist the shaft til the holes line up.)
There's a spacer that fits on the end of the shaft that keeps the gear in position. Don't put it on yet! It'll just fall out. Wait til just before you bolt the rear extension on to slip it in place.
That's everything in the bottom half...next, the mainshaft.
Set the mainshaft in place. Note the rubber band to hold the gears together.
Put the snap ring on the rear bearing. If it has a 'set,' put it on so the edge angles out like shown. (It'll make it easier to wedge the prybar in there next time it has to come out.)
To put the bearing on, set the box upright on its front end. Rest the end of the shaft on your prybar, as shown.
Use a length of 1" pipe down the tail end of the shaft, and pound the bearing home.
You know it's "good and on" when you can put the washer and snap ring on the end.
Now for the input shaft end. Set the 'oil flinger' against the gear first.
Now the front bearing, same as the rear, and pound it home the same way.
Put on the washer and snap ring...
You'll notice I pre-lubed the bearings with all-purpose grease. Probably overkill, but better safe than sorry.
Pre-lube the caged roller bearing, and put it, with its spacer, in the end of the shaft.
Set it in place, and pound the bearing home, using the same 1" pipe method as for the rear. Turning the box upright, with the mainshaft hanging down over the edge of the table, helps.
And that's that. Next, buttoning everything up...
The next thing to do is get the dummy shaft out of the laygear. Chances are, all that pounding has moved it around. Turn the box upside down, make sure the thrust washers haven't moved around, and jiggle and wiggle until the laygear falls into position and you can see the wooden dowel centered in the hole. This may be long and frustrating, and it may seem to be stuck at times. Be patient...it will eventually fall into place. Push the dowel a little to make sure you don't lose the alignment.
And then zzzip...in with one shaft and out with the other. Remember the shaft pushes in from the <span style="font-style: italic">rear</span>.
Now that you know everything's secure, take your handy 1" pipe and tap in the speedo gear. Creep up to the mark--don't overtap!! :laugh:
Moving to the rear extension for a while, pry out the old oil seal...
Tap out and replace the bearing if you have to (1" pipe again!) and tap in a new oil seal. Spring side faces the side you want the oil to stay in :wink:
Using a couple dabs o' grease, stick the gasket in place.
Now back to the box. Put your shift forks in position...
And slide the fork shaft in place. It doesn't have a front or back; it just floats in position.
Remember that neat little interlock spool? Remember how it fit in? Nah, me neither. :frown: Here is a refresher of how it sits on the shaft:
The books say to put the washer on the end of the mainshaft when you mate the halves together. Dont. If the shaft is off even a little, it will dig into the side of the extension. And your shaft <span style="font-style: italic">will</span> be off. Instead, stick it to the inside of the bearing with --yep-- a little grease, and hold it in place with your finger as you slide the mainshaft home.
The books also say to thread the shift lever through the interlock spool and forks as you mate the halves, like this. Don't.
Instead, <span style="font-style: italic">pull the fork shaft out</span>, let the forks lie there, and mate the two halves. Bada-bing, easy as pie and no tricky threading.
In fact, if you feel any resistance at all, it's the end of the mainshaft catching on the rearmost bearing. Lift it up a little, and it'll slide right home. (Did you remember the bushing on the reverse shaft we were saving? Nope, me neither. Take it apart and do it again.)
Bolt the back case on. Ahh, now it's starting to look right again.
Now, line up the reverse fork and the interlock spool...
And slide the fork shaft back in.
Put the interlock plate back in the top of the case...
And button 'er up! (Note the little divot in the far edge? That's the point where it catches on the heater box when it's trying to go over the crossmember. Be warned. :wink:
And at this point, it's ready to bolt up to the engine and pop back in. I didn't take any pics of that procedure, because it was <span style="font-style: italic">so</span> uneventful. It really <span style="font-style: italic">was</span> just going through the list in reverse. Slow and steady with the tilt-lift, a few inches and a few degrees at a time.
And we're back on the road! Thanks for all your positive feedback through this whole experience. I've learned a lot, you've all been a great encourgement to me, and I hope you've enjoyed reading it as much as I've enjoyed posting it.
Wow, I'm impressed.
