Irregular Heartbeat - SOLVED!!
G
Geeze Louise! I wrote such a nice long-winded note to this when I posted it, I don't know why it didn't go, but at least the icon and subject line made it! /ubbthreads/images/graemlins/confused.gif
Anyway, the final solution was a hidden airleak in the rubber cap I was using over the intake manifold's pollution control stem. This engine is from a 1970 Midget, just after they started requiring air pollution control. The PO had removed the system, so when I rebuilt it, I used a heavy rubber cap and a hose clamp to seal off the intake manifold stem where the pollution control hose came in from the exhaust side. I'm only guessing, but I think that during the autocross I ran on August 1st (95F), things got hot enough under the hood, and my heavy foot, created enough vacuum at the intake to actually suck a hole in the softened rubber cap.
I would have never seen this if I hadn't had a club member over to offer his help solving the problem. While he was bent over the carbs using a synch tool, I was in the appropriate LBC prayer position (kneeling in front of the radiator looking quizzically at the engine). My eye happened to glance down the to the area of the valve cover and coolant return pipe. I noticed something that looked like a hole in the bottom of the rubber stem cap. I put my finger over it with the engine running and it immediately smoothed out and purred.
The ironic thing is that I would have never seen this hole in any other postion than where I was at, since it was on the bottom of the cap and "unseeable" from above. I have since placed a permanent brass plug in the stem pipe, sealing it with my favorite repair tool: JB Weld. I am back on the road again.
G
I have edited my original note, since what I wrote apparently didn't "stick". Please see the first note for the solution.
Tim C.
G irregular heartbeat Spridgets 10
K irregular blinker MG 4
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
EricJNewman MGB Weird Brake issue finally solved. MG 1
E MGB MG Idle issues, restart issues solved. MG 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
P TR6 Clutch problem not solved Triumph 6
M A problem solved Austin Healey 0
Basil DIL's O2 sensor problem - SOLVED Other Cars 11
Flash_Harry MGB MGB '74 B-GT with fuel problem - SOLVED [I think!] MG 4
andrea PROP ROD BONNET RATTLE easy solved Austin Healey 9
B Oil Pressure Issue Solved 3000 BT7 Austin Healey 1
L Turn signal problem solved [sometimes its not your fault] Austin Healey 6
G My engine keeps conking out problem solved! Austin Healey 2
DanLewis Solved the oil cooler mounting problem in my Bugeye! Spridgets 8
T TR6 TR-6 Clutch disengagement issues, recurring or solved ? Triumph 6
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
R TR4/4A Tr4a horns problem solved Triumph 4
HEALEYJAG 73 E-type Roadster short solved- NOW........... Jaguar 9
P Coolant leak solved Triumph 1
T Sqeeling Clutch Problem..SOLVED Triumph 2
Gliderman8 Problem solved! Triumph 5
tr6nitjulius Problem Solved! Triumph 4
Morris Mystery solved! Spridgets 14
G Vapor lock issue solved [RB cars only] Spridgets 22
Tinkerman TR2/3/3A Overdrive Switch question. TR3A, Problem Solved! Triumph 10
hondo402000 TR6 Leaking Transmission solved TR6 Triumph 5
pjsmetana [solved] Sunpro Fuel Gauge... going crazy! Triumph 29
A Oil leak solved - the footpower stomp Latest Austin Healey 0
rlandrum TR2/3/3A TR3A Low Oil Pressure Solved Triumph 19
1965_MGB VB SU fuel pump kits, any experience? *Solved* MG 0
jackq nightmare o/d problem solved MG 0
jjbunn Call for help: Pasadena, CA UPDATE PROBLEM SOLVED! Triumph 15
regularman One problem solved. Spridgets 2
G Solved my Master Cylinder Reseroir Leak problem... Triumph 6
O tach problem solved? Spridgets 4
healeyboz Allright Fellas --- Problem to be solved!! Spridgets 39
B New gas tank issue [SOLVED] Spridgets 14
RickB Gassy smell in cockpit - Solved! Thought I'd share Spridgets 4
budk1953 One problem Solved? Spridgets 6
Bret Mystery Coolant Leak Solved! MG 3
kyreb1862 Disappearing Brake Fluid Problem Solved [Sadly] MG 8
WidespreadPanic TR6 '74 TR6 Fuse Box [UPDATE] SOLVED! Triumph 27
PAUL161 MGB The Australian CKD MGB - Mystery Solved! MG 2
MadRiver Alternator problem solved Triumph 0
8 84 jag no start SOLVED Jaguar 1
P MGB overheating 63 mgb solved :] MG 10
C Solved TR 3 tuning problem Triumph 2
G Starter Switch Mystery Solved! Spridgets 2
R Windshield problem solved! I think? MG 0
