How fast are Minis?
DesertSprite
Aloha,
I was just reading an issue of Mini World where they had a Mini club from the UK run all their cars on a dyno to see what their cars are producing in terms of bhp. A couple of them were downright sorry with only about 25bhp, however, a couple were around 85bhp and one had 120bhp.
That being said, how much does a Mini weigh? What sort of hp:weight ratio do these horsepower numbers produce?
Just interested in exactly how fast a Mini can be (I know they're quick in the corners) with such a wide range in horsepower being produced by the A-series engine.
aloha,
Joel
Xracer
Well, there are Minis and there are Minis!
Are we talking stock Minis? What model, what engine, what year?
A Mk.I or Mk.II Cooper 1275 "S" weighed about 1440 lbs. (in regular road trim) and produced 76 (advertised) bhp. In good tune, on a long straight road, you could probably do just short of 100.
Later, fuel injected models produced more hp, but also weighed more....so maybe they could do 100 or just a little more.
The big problem with top speed in a Mini is aerodynamics....they don't have any!
You've gotta add a lotta horsepower for a little gain in top speed.
A 120 hp Mini would accelerate like scalded cat, but would probably top out at only 110-115 or so.
DesertSprite
Hi Xracer,
Most of the Minis in the article seemed to be later model ones like the Mini City or Mini Sport...ones that were never imported to the U.S. A few of them had the 998cc engine (?) and some had 1275cc and others had 1380cc engines.
I guess I'm not too worried about the top speed of a Mini, just wanted to know how fast one could accelerate. The only racing experience I have is in drag racing. Have any specs on a suped-up Mini in the 1/4 mile? It would put things into persepective for me.
aloha,
Joel
Bugeye58
Several years ago, David Vizard ran a 112 hp Mini at the strip, and clocked a 14.2 @ 89.9mph. Too much wheelspin in first and second.
Jeff
ThomP
Joel
Keep reading Mini Magazine and Mini World. They routienly publish 1/4 mile times for Minis (and now most likely MINIs). I have seen NOS times in the high 9s, yes 9 seconds for the Mini. It is rare, but they do exist.
Xracer
I have some "real-life" experience here. I lived about 2 miles from Connecticut Dragway (now the Consumer's Report Automotive Test Site) and often took it there.
My stock '64 Mini Cooper 1071 "S" would usually turn the 1/4 mile in the mid-18 second range. My fastest time was 18.2. Since the 1071 "S" would accelerate as fast as the stock 1275 "S", they would do about the same.
Those were the speeds of stock, road going, Mini Cooper "S"s of the '60's.
Nowadays, with very modified engines (and probably tube frames, rear wheel drive, aluminum bodies, VTech engines....maybe even Hemi-Chryslers, etc.), I'm sure they're much faster.
[ 01-09-2004: Message edited by: Xracer ]</p>
huck6
How about say a Mini 1000 in daily driving? Can it keep up at 65 to 70 mph?
Sherlock
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr> Huck6 said: How about say a Mini 1000 in daily driving? Can it keep up at 65 to 70 mph?
<hr></blockquote>
My understanding, merely from talking to Mini owners who I know, is that a Mini with the 998cc engine is capable of freeway driving. However being a small motor, it will make the driving experience a little noisy, but it is certainly up to the challenge. For a little nicer freeway driving try to track down a Mini 1000 that has had a BMC 1275 installed, but the 998cc engine is still good enough.
I even know a guy who has driven the freeway between Montreal and Kingston, Ontario to attend a car show in his 1959 Morris Mini Minor (with all of 850cc engine), this would be roughly a 3 to 4 hour drive one way, but that smaller engine isn't generally reccomended for freeway running.
Xracer
A Mini 1000 will cruise reliably all day at 75-80....the only problem is that it will be a bit "buzzy". They were normally fitted with a 3.44 rear end as a compromise between acceleration and top speed.
If you're going to do a lot of highway driving, I'd suggest that you install a 2.9 rear end (though, actually, it's in the front, isn't it?)
I had a '65 Austin 848 with drum brakes. Loved the handling, but I drove from Richmond to Blacksburg, VA in the summer. Could barely hold 70, and nearly overheated (stopped at the top of a mountain to cool off). When I got home, I sold it to an aspiring racer who planned to change to front discs and a 1275.
Twinkie
I basically burned up a 1000 engine in my '73 by driving it at 60 to 70mph. Anything over 30 deg C and the cooling system can't keep up. And the revs are way up there at those speeds. I wouldn't recommend daily high way commuting in one. Too bad an "affordable" 5 speed wasn't available.
I guess if one was able accept more frequent bottom end rebuilds of the engine, you could run one regularly at higher speeds.
Super 7
I heard that at higher speeds the fan looses its ability to move air through the wheel well to cool the radiator.
14.2 in the quarter is pretty quick. My Brother's Sunbeam Alpine 1750 ran 18.65. My Ford Cortina 4 door ran 18.8 at 80.
Those cars are not about drag racing.
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
Hamish Racing TR2/3/3A Fast Road TR3a on figure of 8 sprint track - UK Triumph 10
B AH Spares Fast-Flow Fuel Manifold Austin Healey 2
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
T TR2/3/3A What causes fast flashing turn signals when all bulbs & indicator light are flashing? Triumph 15
HalLucy Post-War Other Renown - Idle too fast Triumph 5
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
P Fast Healey at Lime Rock. Austin Healey 2
wkilleffer MGB Air leaks and fast idle speed MG 11
HealeyPassion AH Spares Fast Flow Manifold.... Austin Healey 32
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
T TR2/3/3A 1/4 mile fast time driving technique Triumph 15
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
DerekJ Indicator blinking too fast Austin Healey 13
D Piper Fast Road Cam Installation Austin Healey 9
D Fast Road Cam Austin Healey 2
B Fast Idle Spridgets 7
steveg Fast and the Furious on Friday Oct 25 Austin Healey 2
glemon Better Move Fast Spridgets 4
NutmegCT TR2/3/3A low idle after a fast run - TR3 Triumph 4
KVH Idle Too Fast Triumph 36
drambuie Old British car film..... The Fast and Furious 1955 full movie Austin Healey 17
L Fast idle? British Motor Corp 4
StagByTriumph GT6 1968 GT6 for sale in Colorado Auto Parts Salvage - act fast Triumph 8
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
lbc_newbie MGA Someone needs to get this, fast... MGA $1500 in SC MG 4
HerronScott OT: Honest officer, I wasn't going that fast... Triumph 8
C An MG in fast company... Racing 0
HealeyRick The Fast and the Furious XK 120 Jaguar 2
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
MadMarx [video] Zandvoort - fast qualy lap Triumph 11
PAUL161 Stirling Moss in one fast MG! 1957 Bonneville! MG 7
T Thoughts on surviving a 600 mile fast road rally Triumph 17
B Tired of fast food style restorations? Restoration & Tools 7
T Post-War Other How says a Herald isn't fast Triumph 19
C REALLY fast British race car [circa 1971] Racing 0
Jer First Drive of 2010 Season is Fast Approaching... Spridgets 11
T APT Fast - great experience Triumph 3
P TR6 76 TR6 fast idel problem Triumph 5
livinginthepast Quick question on setting fast idle/balancing carb Spridgets 21
frankenstang57 Spitfire Spitfire 1500 fast road cam question Triumph 4
X Weber 32/36 DGV fast idle rod MG 0
NardisCNC How fast can you pull your Midget engine / trans?? Spridgets 17
jdubois TR2/3/3A TR3A fast idle cam connection? Triumph 26
T TR6 How fast can a TR6 go? Triumph 51
aeronca65t Fast British Car Other British Cars 5
C TR6 Very fast TR6 youtube vid Triumph 16
aeronca65t Fast Ford Transit Van Other British Cars 9
