livinginthepast
Hey there,
I'm still tweaking, trying to get the carbs set up just right - H1s on 60 BE.
I'm curious how you all set the fast idle. I'm getting pretty damned proficient in quickly balancing the carbs, still struggling with the mixture (not sure why I have to back off the mixture nuts so far to get a decent mix - but maybe I'm not interpreting the manual correctly).
So the fast idle screw, as those who have been following my education in carbs, has been giving me trouble. The issue with holding the screw in place was in fact the spring. But I have a more pressing question. What is the correct procedure for setting up the front carbs two idle adjustments? I've just been playing it by ear - as my manual really doesn't say anything about it.
Oh, one other thing with the needles. I had to tweak the needle position (recessed into the piston body slightly), but I was wondering how these needles are intended to be positioned. These are standard GG needles (moss 374-095). I started by positioning them flush with the bottom of the piston. Shouuld I have pushed them all the way in to the piston?
Thanks!
Thanks!
