Fuel Gauge Needle Shakes
af3683
The fuel gauge needle on my TR3B is constant when the ignition is in the on position, but shakes when the car is started. The wire on the gas tank send unit is secure. If tried to check the conections on the back of the fuel gauge, but am having trouble getting my hand up there. Is some shaking of the needle normal?
Thanks,
Art
Brosky
Art, that really does sound like a loose connection. Is the sender tight in the tank?
af3683
af3683
I know that the sending unit connections were tight last October because I checked them before I installed a millboard panel. I'd be surprised if they loosened up because I have not driven the car much.
DNK
Might be the alcohol in the fuel
Bourbon makes me shake
TR3driver
Great Pumpkin - R.I.P
Most likely IMO would be a poor ground at the gauge. Although I'm still not certain if the factory installed a ground wire or not; the vast majority of cars seem to be relying on the clamp to ground the gauge to the panel, which is far from secure. TR4-onwards doesn't need a ground for the gauge, but the 'balanced' gauge used on TR2-3B does.
af3683
af3683
I checked the clamp on the fuel gauge and it appears to be fine. I'm now back to examining the ground wire from the gas tank sending unit. My ground wire goes from the sending unit to the <span style="text-decoration: underline">left</span> strap that secures the gas tank. Specifically, the bolt goes thru the strap which goes thru the ground connector which then screws into the trunk. Does anyone know if this is the correct sequence or should the bolt go thru the ground connector and then thru the strap and then into the trunk? Also, any chance that the ground should go to the <span style="text-decoration: underline">right</span> strap or does it matter? Thanks again.
Art
Brosky
Art, just try running another ground as a jumper at both ends to see if the problem stops.
NutmegCT TR2/3/3A Fuel gauge needle replacement TR3A Triumph 0
G MGB ugh.....the fuel gauge went to *** again! MG 8
roscoe Fuel Gauge Austin Healey 0
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Fanch00 Inoperative Fuel Gauge Austin Healey 10
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
R TR2/3/3A Fuel Gauge Triumph 19
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
C MGA Fuel gauge question MG 8
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A Fuel gauge readings? Triumph 12
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
K TR2/3/3A Fuel Gauge again.... Triumph 11
N Fuel gauge problems? Spridgets 9
warwick-steve Fuel Gauge always shows 1/4 full Austin Healey 27
N Fuel gauge problem's? Spridgets 4
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
George Zeck Looking for a fuel gauge ...... Spridgets 2
S Fuel Gauge Question Austin Healey 8
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
warwick-steve Fuel Gauge always indicates 1/4 full. Austin Healey 13
J Fuel sender, fuel gauge 100 4 Austin Healey 6
George Zeck What fuel gauge SHOULD I have? Spridgets 3
sim 1958 fuel gauge sprite Spridgets 11
N Spitfire Fuel gauge Triumph 8
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
N Fuel gauge question?? Spridgets 3
B TR2/3/3A Fuel gauge problem Triumph 7
H TR2/3/3A Fuel sender or gauge? Triumph 8
F Running out of fuel - gauge problem? Austin Healey 5
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
K TR2/3/3A Fuel gauge and switching to Neg ground? Triumph 2
K TR2/3/3A Can a TR4A fuel gauge be used in a 3A? Triumph 8
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
Rut Bugeye fuel gauge Spridgets 14
