Finally some time to work on overdue Bugsy Projects
Jim_Gruber
For the first time in well over a year I am in between Kitchen Remodel and Bath Remodel Projects,awaiting flooring to arrive,and I had some time to start work on Bugsy last evening on a long overdue replacement of Brake Master, Hoses, Fluid, Adjustments, et al. Got Bugsy up on jack stands and out came Brake Master and Clutch Master. I managed to get all out and not get fluid everywhere. Man was that fluid dirty. Last time it was changed was a long, long time ago. Will bleed and flush everything and make sure there are no leaky rear wheel cylinders as I go through it all. I cleaned up some paint issues under the MC, so easy when car was painted with Rustoleum to begin with and let things dry overnight. About to head back out to the garage decked out in winter wear to reinstall both masters and to see if I can get hoses changed out this afternoon as well. It's been 12 years since hoses were changed. Way overdue I know and I noticed some braking issues with front brakes pulling this summer when I drove Bugsy in August. He's been parked since for safety reasons and this was the first spare time I've had to work on him.
And of course forecast for this week calls for 56 Monday, 65 Tuesday, 54 Wednesday and Bugsy is up on jack stands. Time to get busy on Bugsy there is a wallpaper steamer for the kitchen in my near future that is calling. My wife realized I needed a break from the remodeling project and getting time to problem solve and playing with Bugsy puts me in such a better mood. Time to get busy.
nomad
Might as well do rear cylinders and calipers while your at it, Jim. Pulling to one side usually isn't cured till you do. I personally like Dot 5 fluid but I'm sure that the mere mention of that will bring on a barrage of controversy. Fitted it to my MGB when it first came out in the 70's. A friend now owns that car and has no brake issues---I don't believe they have ever even been bled!!
Kurt.
Jim_Gruber
Jim_Gruber
Kurt,
New Brake Master installed. Clutch Master I'll leave as is after cleaning out. All buttoned back up. Had to fight one of the brake lines as I cross threaded and had to fix with a 3/8 x 24 die. So will be interesting to see if I got it cleaned up properly or will need to replace the line. Appears I may have had a leak there as threads on the brqake line were corroded. Can I use some kind of Teflon or plumbers tape if I get a fluid leak there?
On tonight's agenda, replacing front and rear hoses. I have wheel cylinder kits so I will take a look at the rear wheel cylinders and likely replace seals. I'll make sure no leaks, adjust rear drums, and adjust E-Brakes and button things back up. Goal is to make everything safe before Bugsy goes up for sale in the Spring. Gotta make room in my one car garage for a BE that is coming home in March.
G
Kurt,
Nope, the flare does all the selaing. Asking that question while in school would have only assured a 3 1/2 pound text book speeding in your direction propelled by an old cranky German.
"VHAT DID YOU ZEY" ...SWOOSH.....
Jim_Gruber
Jim_Gruber
Work on Bugsy slowed to a dramatic halt after a productive session Tuesday night. Was not feeling all that well when I was suddenly overcome with a severe wave of nausea. That passed and I attributed it to a bug. Same thing came back Wednesday evening and about 2:00 AM I went to the ER. Diagnosis GallBladder Red and angry and full of gall stones plus a 9 cm gallstone in my 7 cm bile duct. Not a good situation. Surgery late Thursday and then another endoscopic procedure on Friday morning to remove the stone. The miracles of modern medicine and technology. One to two weeks before I can return to work and the weight restriction says no work on Bugsy for at least 2 weeks. OVerall not much pain but they did need to catherize me after surgery and that's the worst part of the recovery. Catheter comes out today and I can resume almost normal life again.
On a positive front, I do believe I've found a Buyer for Bugsy my '68 Sprite with a BE Bonnet. Details still being finalized but Bugsy may be on his way soon to the Northeast. $ and a 5 speed as part of the deal will help to fund restoration of a '59 Bugeye in pieces which I purchased. Need to make room for Bugsy II. Come on Spring, Hey it's now 45 days until it's officially Spring. Let's get those winter projects in gear. We will survive what has turned into a crappy winter in the last 2 weeks.
Good news 2 - Son In Law volunteered to recruit a couple of friend to install hardwood floors in kitchen which was planned for next weekend. That is excellent news as well.
JPSmit
Get well! Gallstones are nasty.
Jim_Gruber
Jim_Gruber
Thanks JP. Once I get well, coming your way in March to pick up Bugsy II.
mctriumph TR2/3/3A Finally painted the 63 3b Triumph 14
J TR2/3/3A TR3A Finally on the Road! Triumph 6
AngliaGT Finally - A (Mostly) True craigslist Ad Other Cars 0
Grantura_MKI Pre-War Finally arrived. MG 7
HealeyPassion Finally, paint on chassis Austin Healey 17
Lou E Finally a Bugeye of my very own Spridgets 41
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
Bayless A Sprite gets some paint finally Spridgets 2
EricJNewman MGB Weird Brake issue finally solved. MG 1
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
J Shroud Painting ["Finally done with these"] Austin Healey 3
Rhodyspit75 Finally on the road Spridgets 7
AngliaGT MGB FINALLY Got the Engine Out MG 5
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
Tr3aguy TR2/3/3A Tr3 frame work finally Triumph 93
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Basil I finally joined Jaguar 4
J General TR Finally on the road Triumph 1
Bayless More Sprite progress finally Spridgets 23
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
Bayless Progress finally begins Spridgets 5
tinman58 General TR Finally almost Triumph 7
J TR2/3/3A Finally getting started Triumph 20
Elva164 Finally did another onboard video! Racing 4
J It is driveable! Finally. Morris 8 Other British Cars 8
M Finally Joining the Bugeye club! Spridgets 20
simon1966 Rain cleared up so finally got out. Austin Healey 31
tomshobby TR6 Finally finished my custom steering wheel. Triumph 12
B The Prince of Darkness on the dash board finally conquered Austin Healey 10
vickxxx T-Series Finally MG 3
Sarastro TR4/4A My TR4A finally arrived! Triumph 11
B Scuttle shake finally sorted Austin Healey 23
B Finally - BJ7 painted Austin Healey 3
Jer when something doesnt make sense... and you finally figure out why ! Spridgets 4
Basil Back to the EType finally Jaguar 5
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
drooartz Finally found one Spridgets 8
L Are 100's finally eclipsing the 6 cylinder cars Austin Healey 6
trrdster2000 GT6 Finally got a photo of some of our work on the Spit 6 Triumph 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
Steve P. Finally found a RWA Midget Spridgets 1
CJD TR2/3/3A TR4 Gearbox in the TR3...Finally! Triumph 3
R GT6 Finally Finishing Triumph 19
Sherlock It's driving season finally! Spotted 5
J Finally a fix for the SU pump Austin Healey 5
F MGB Finally got my 78 MGB on the road MG 5
F Spitfire Finally Mobile! Now Grind/Rubbing from Clutch, Gearbox Or? Triumph 5
mgedit General TR Finally a Sniff of Spring Triumph 3
