Ohiobugeye
I was ready to start a re build on my 948 cc engine for my Bugeye and happened to come across a rebuilt 1275. The 1275 is missing the flywheel and the exhaust manifold. Will my 948 exhaust manifold work on the 1275? I see in the parts catalogs both engines use the same manifold gasket. I will be using the standard bugeye 948 exhaust pipe. I also will be using either my 1-1/4 S.U. carbs or a Weber. As for the flywheel, I'm almost sure the 948 flywheel won't match up on the 1275. Any answers? Thanks
