Re: Dash being refinished but would like to recove
Go to this member's web site by clicking on the
link here:
https://www.74tr6.com/glassreplacement.htm
Do you see the extended tubes on the bottom of the
windscreen frame? There you'll find two nuts with
washers. They are on the inside of the car. Look up
near the hood latch release, then cast your eyes
backward along that plane. You'll see the tubes that
go to the windscreen with the nuts and washers. Remove
them.
Now open your car door and loosen the bolts on the
inside of the door jam. One will be holding the fender;
the other is the one you loosen. I say "loosen," not
remove.
Take a wide plastic putty knife and carefully break the
windshield rubber at the bottom of the windscreen loose
and away from the car. It could have a little glue holding
it down.
Now with a helper, step/kneel/whatever, inside the vehicle
and each of you pull/tug/jerk, somewhat, on each end of the
windscreen. Your entire windshield with glass in the frame
will pop out revealing the dash pad.
There will be more, though. I think you might have to drop
your wood dash forward, or moreover, remove it altogether.
This now makes the task more time consuming and challenging
if you find you must remove the wood dash altogether.
Maybe somebody else with a different experience than me can
comment or help.
Your car will likely be out of service for a while, whatever
you do, by the nature of the repair.
Best of luck and contact us again if you need more help.
