Dash refinishing help
64 healey
Hi I’m in the process of refinishing my dash
panels in my original 64 3000 with just 52,000 miles. I’m a car,boat,motorcycle crazed nut from way back when. This sight seems to have some very useful help that I am in need of.
Hello 64healey and welcome to the BCF.
You will get more answers by posting your question in the “Austin Healey” section of the forum.
I can tell you that when I refinished the Walnut dash on my TR6 I sanded off the old veneer the used PRE-CATALYZED Veneer Adhesive. It holds up better than contact cement. After I applied the adhesive, I sandwiched the dash between two pieces of plywood with bolts and wing nuts strategically placed. Tightening the wing nuts gave me the clamping pressure I needed while the glue dried. I finished it with UV Marine Grade Polyurethane.
Hey there 64, I'm going to move this thread to our Austin Healey forum where you will be more likely to get answers. If you're reading this, then you are now in the Austin Healey forum. I will leaver a "pointer" in the New Member Introuctions forum (where you originally posted your question).
When you have a chance, go back to the "New Member Introductions" forum and post an inroduction for yourself. Tell us a bit about yourslef.
Cheers, Basil
When I did my dash on my TR250 I peeled/picked the thick varnish off the surface leaned and very lightly sanded and then simply finished with some Minwax clear poly and it ended up looking great. But how it ends up will be dependent on where it starts, a lot of people re veneer their dashes too.
