Tinster
Allan et al:
The numbers? Since I know just about nothing about
mechanics, I always mark the locations of circular
pieces I remove. I mark the piece and also whatever
is behind the piece. I can then line up the two marks
and the piece is in place exactly where i removed it.
But the flywheel rotated so the numbers were useless!
I tore out the clutch simply becaue I had a "Sticky"
clutch when I let it out. All suggested a broken taper
pin. I found a broken taper pin.
The clutch worked just fine with no shuddering, slipping
etc. Even under heavy acceleration.
I think I will give up on removing the flywheel and
just attempt to install the clutch.
Anyone see any defects in this flywheel?
Hi Guest!
