Coolant Leak From Fill Neck
MY66AH
Seem to now have a new issue. The radiator cap dosen't seem to seal on the fill neck. I get coolant comming out the coolant dump hose. Should I get a replacement from Victoria?
JPSmit
I seem to recall that at least some if not all the radiators require a deeper depth rad cap than the standard Advance Auto type, so, yes, probably time
nomad
Right JP, though my local auto parts store could get me one once the difference in depth was pointed out. Can't get the low pressure one anymore though. I believe 7lb's is the lowest and that will swell your header tank on a early radiator. Experience!
Kurt.
B TR6 Triumph tr6 coolant leak Triumph 4
B Oil (or Coolant) Leak Austin Healey 10
gfholl Coolant Leak Spridgets 9
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
T coolant leak Spridgets 2
P Coolant leak solved Triumph 1
P Coolant leak Triumph 0
7 finding a coolant leak Other Cars 8
T finding a coolant leak Austin Healey 3
Shinsen774 Coolant Leak MG 5
2wrench Help to find coolant leak Triumph 8
Lin Frustrated - Coolant Leak at Drain Tap Austin Healey 2
Jim_Gruber Coolant Leak / Temp Sensor in the block Spridgets 10
bcbennett Interior coolant leak Triumph 6
Bret Mystery Coolant Leak Solved! MG 3
sonuvagunsmith Radiator/coolant leak MG 6
sparkydave Mystery coolant leak Spridgets 4
J Need new ideas to find a coolant leak!! Triumph 14
D TR4/4A TR4 coolant leak thru head bolt Triumph 7
W coolant leak Jaguar 4
W coolant leak Jaguar 1
S Spitfire Cyl head coolant hose fitting Triumph 1
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
FlyingCat Spitfire Losing Coolant Triumph 12
M TR6 1973 TR6 Coolant Type? Triumph 5
R Coolant temperature gauge Spridgets 8
Govtslug TR6 Coolant Temp Q Triumph 4
T TR2/3/3A TR3 coolant hoses Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
nevets Coolant Temperature Austin Healey 13
L BMC A-series: Oil in coolant British Motor Corp 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
K TR2/3/3A Radiator coolant level? Triumph 5
M TR6 '72 TR6: Oil in Coolant Triumph 25
W TR2/3/3A location of the coolant drains on a tr3a Triumph 4
Got_All_4 Wedge Tapered coolant hose for a PI car. Triumph 3
Paulus TR4/4A Coolant pressure Triumph 5
D TR2/3/3A Coolant tap on TR3 block Triumph 3
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
S TR2/3/3A Replacement of Engine Coolant Drain Triumph 3
B All the coolant in the wrong place Spridgets 17
G TR4/4A Thoughts on my coolant Triumph 12
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
JFS Wedge Low Coolant Light Triumph 7
Boink Waterless Coolant - thread from the AH forum Spridgets 18
PatGalvin TR2/3/3A Coolant System Hoses Slipping Triumph 5
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
Jim_Gruber Replacing Spridget Coolant Spridgets 21
T TR4/4A Coolant in the oil - again. Triumph 18
