bj8 rotisserie
saltiga
hello again
does any one have the dimensions for the construction of a bj8 rotisserie? this is to make it easy for the painting process
thank you in advance trevor short.
John_Progess
Trevor,
I made a structure that allows the frame to be rotated at 90 degree increments and it is for the frame structure without the fenders, shroud etc. With the frame attached you could, with help, rotate the entire car on either side. I made it out of 1 1/2" tubing and conduit. I would include a picture but I have not had any luck including pictures in my posts. I could get dimensions to you if you think this is something you could use. Hope this helps and have a good day!
I previously used one from Accessible Systems, when I was doing some extensive work on a Triumph GT6. At that time (roughly ten years ago), it cost about $900.00. It was the version with the hydraulic jacks (recommended).
Considering the cost of materials and the labor required, I would not waste my time trying to build one and would just get the store-bought model.
Remember, your safety is paramount, so please don't take any risks to save a few hundred dollars.
dvu101
My friend made one out for wood following a pattern in one of the Healey national mags about a dozen years ago. He used it on two AH cars and now it has passed to another couple of MG owners. It has always had a car on it all these years and its still going strong. I think the biggest expense was the 4 wheels. I have seen it and it looks good. However, you cannot rotate it. He made it for well under $200.
Barryp
Hi guys, I'm pretty cheap so I made one out of two engine stands. One was store bought the other a homemade version. I put swivel casters on all three legs for convenience. Fixture bolts to the original bumper brackets front and rear. Rotates 360 deg without the the shrouds and fenders. It served me well on an MGB project several years ago, and now the BN4 is on it. If I can remember how to post a picture i will attach some.
Barry
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
