• Hi Guest! Being a Paid Subscriber is NOT required to participate at BCF. However, if you enjoy BCF and find our forum a useful resource...
    Please consider supporting us by **Upgrading**
BJ8- How is the chrome door top molding installed?
John_Progess
This was not attached to my car when I got it. Is the rubber weather strip attached to the chrome molding with the push on clips and then this attached to the door top extension using the same clips? Thanks and have a good day!
John
Keoke
John
Yes John thats how it is done. Your day will improve too when you get it to snap back on--Keoke- :smile:
Jerry
Isn't there a tenax stud just behind the wind wing for the tonnaue attachment. Does this go into the door?
J
John_Progess
As far as I can determine it is a lift-the-dot stud and it is attached to the chrome molding only.
Keoke,
I can tell that this is not going to be an easy chore! Do you need to have the window in before the rubber weather strip and felt strip are attached? Thanks again and have a good day!
John
AUSMHLY
Hi John,
Yes, the lift-the-dot stud is attached to the chrome molding only.
Yes, you should have the window installed first.
Use some dum dum behind the chrome top molding to help keep it in place.
Good luck.
Roger
Keoke
:nonod: It is attached to the Chrome finisher only
Keoke
Keoke,
It is just a bit tricky but not really difficult.
No it can be fitted with the window in or out,
Thanks again and have a good day! :cheers:--Keoke
John
davidb
I'm happy somebody asked this question first, because my chrome finisher strip kind of popped off and I was fiddling around with it today, trying to re-attach it. I was using the clips alone and it attached fine and was tight on one side, but the fit was difficult and sloppy on the other side. When I replaced a vent window frame last year, and removed the chrome finisher I noted a thick strip of silicone seal stuck all along the back of the finisher (tough to remove) and thought the last guy was just too lazy or more likely too frustrated to fit the clips properly. But from what I now read, and from the sloppy fit on one side, it seems that a few blobs of "dum dum" is in fact the right way to go, so thanks AUSMHLY for the tip.
Keoke
Hi David, If the fit of the finisher is sloppy on one side there is somthing amiss over there. Ypu should not have to glue them on. Perhaps the little lip at the back end of the finisher has been bent out or the clips are weak.--Keoke
davidb
Hmmm - thanks Keoke
It seems that the chrome finisher doesn't come down far enough on the flat flange of the door to allow the clips to get a "bite", altho the finisher lines up nicely with the smaller "tailpiece" on the rear shroud, and the leading edge slips into the 'tang' at the front of the door. It could be the clips, altho they were new and pretty tightly sprung. The finisher itself is pretty good, with no evident bends.
I may have to bring along the 10 pound sledge enforcer for a little chat...
Working on Healeys is so character building. It's a wonder we don't all end up as serial killers.
Regards, your cheque is in the mail. Does Basil chain you to the computer? You must feel like a galley slave....
Dave
Keoke
Hi again David, You might compare the new clips with an old one might be a bit off. I can remember I had to go get old ones because the new ones did not work right. But be sure the clips are bottomed on the finisher and press down hard when trying to set them on the flange. Sometimes it is necessary to go back over the finisher and hit the top of it with the heel of your hand---Keoke
davidb
OK thanks again Keoke - I'll give another go, with your suggestions...Failing that, I'll pick you up at the airport, if and when you can find the time...
D.
Healey Nut BJ8 door Chrome waist strip Austin Healey 14
C BJ8 Windshield re-chrome Austin Healey 9
tahoe healey BJ8 chrome switch plate Austin Healey 11
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Dowel Bolts Austin Healey 35
AUSMHLY BJ8 Mainshaft needle rollers 32 or 33 Austin Healey 5
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 0
AUSMHLY BJ8 selector shafts and forks condition Austin Healey 2
LAW75 BJ8 Directional Indicators Austin Healey 4
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
W BJ8 Transmission Installation Austin Healey 0
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
Patrick67BJ8 Weatherstripping Seal & Caps for BJ8 Austin Healey 6
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 9
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
AUSMHLY BJ8 Laygear Wear Austin Healey 11
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
S 1964 BJ8 Project Valuation Austin Healey 17
AUSMHLY BJ8 Factory Hardtop Headliner Austin Healey 2
J Early BJ8 Armrest Latch Austin Healey 2
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
AUSMHLY BJ8 Gear Shifting Austin Healey 5
S BJ8 Overdrive Stays Engaged Austin Healey 25
LAW75 BJ8 Door Locks Austin Healey 2
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
W Late BJ8 Seat Belt Mounting Points Austin Healey 8
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
JamesD BJ8 Top Frame Bumpers Austin Healey 12
AUSMHLY BJ8 Driveshaft Installation Austin Healey 10
M BJ8 Inner Body Panel Repair Austin Healey 2
crispy BJ8 Front Suspension Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
BJ8Healeys Original Metallic Golden Beige BJ8 for sale Austin Healey Classifieds 0
M BJ8 Seat Thickness Austin Healey 6
D BJ8 Headlight Rims Austin Healey 0
B RHD BJ8 Throttle Control Rods Austin Healey 9
J BJ8 Radiator Fan Austin Healey 12
H BJ8 Heater Valve/Control Tap Austin Healey 3
R BJ8 Upholstery Austin Healey 5
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
T BJ8 Drain Channel Removal Austin Healey 2
B BJ8 Phase 1 Electrical Diagram Austin Healey 15
