Approaching Week 25
OMG
I'm procrastinating. The tubs are every bit as bad as I thought they were. In another thread I recommended to Steve to sit back and assess the situation with a beer.
I bought a whole case this week.
Rather than beat around the bush, I'll post pics showing the situation. There are 2 main issues going on at once. First, I bought the TR3 tub to replace the TR2 rusted out tub. They look the same at first glance, but there are many more differences than appears at a quick glance.
Second, some parts of BOTH tubs are rusted out. The donor tub has been patched with fiberglass. That sucks. The floors are holed worse than I initially thought. Bottom line, the donor tub sucks.
TR2 Vs TR3 Differences
These are the 2 tubs. For the first time in 3 years I am to the point they are completely dissassembled and can be set next to each other for comparison. First glance not to bad?!? It gets bad...
Starting at the front, this is the headlight relief for a TR2. Just a hole.
TR3...has a hole for the bumper mount, no hole for the headlight, a reinforcement patch, and a relief for the headlight. Uhg. If you guys have learned anything about me, it's that I am annul when it comes to restorations. I can not just leave this in TR3 style and in good conscience pass the car off as a TR2.
Continuing...
It's been so long...I think this is the TR2 horn mounting pad?
TR3 horn pad. Different shape and hole spacing.
TR2 has the hole for a RHD steering column.
TR3...nope.
TR2 radiator brace. It uses just a hole for the brace rod to bolt to.
TR3...a slot.
TR2 has the brake/clutch opening for RHD.
And, of course, the TR3 not.
TR2 has no front scuttle vent.
You guessed it...TR3 does.
Funny illusion on this pic. I am trying to show the thin slots for the brake and clutch pedals...but the rust from the floor seems to fill in the holes. Rust, rust, rust...I am so tired of looking at rust.
TR3 has larger slots for the disc brake set up.
Speaker hole TR2.
None TR3
TR2 has these factory holes to mount the small windscreens.
They went away by the TR3
No cleaner sprayer holes for the TR2 windshield.
TR3 has sprayer holes by the wiper slots.
Just like the door frames, the TR2 uses a wood insert for the dash edge.
TR3 went with an all-metal dash edge
TR2 rear cockpit edging has few holes.
TR3 added a bunch of extra holes.
TR2 rear valence has no extra brake light pintles. The brake light is in the license plate light assembly.
Gotta get rid of the TR3 pintles.
AND just when I thought I had caught all the differences...I found a subtle one with the way the kick panels attach. The tr2 kick panels are full length, extending all the way down to the floor boards.
OK, I know what you're thinking..."what floorboards?" I hear 'ya!
This is a view of the outside of the kick panel where it disappears inside of the inner sill.
The TR3 stops at the top of the sill and is spot welded to it there.
Gotta take the wife to lunch. The tubs aren't going anywhere soon. When I get back I'll show the pics of the damage problems, which adds complication over and above the simple "difference" complications. Bummer...still before noon so too soon to start drinking.
Or is it??
