Air filter cannister guests
jjbunn
I pulled out the air filter to check its condition.
Here is what I found:
:pukeface:
PAUL161
But Basil, it's cold outside and those little guys have to have a warm bed also. :cryin:
T
TRDejaVu
I found evidence of their summer home inside my sills. If you have any small holes (rust or otherwise) they are probably in there. Another good excuse to do a structural check on the car.
LarryK
Got the winterized baby in the garage? Dog food nearby? Used to dewinterize cars to get ready for shows. As cars were towed to shop and pushed backwards in stalls, upon startup they would shoot dog food from the exhausts at the walls. We had a V-12 that actually shot baby mice out. Stored outside? Mice in the heater core housing and in the seat foams. A mouse can squeeze in a crack 1/8" narrow.
Newer cars too! My brother-in-law bought an 05 Cooper S and when we changed the cabin filter we found 2 dead mice. My sister-in-laws 03 MINI was always parked outside. Her gas mileage dropped horribly and the car had lost it's pep, found the engine air filter over 75% clogged with a mouse nest.
Andy Blackley
I put my car in storage using one of these: https://www.classiccarcocoon.com/car.html
You drive on it, and fold the top over the car, then zip it closed. It has a rubber strip around the zipper to help seal it, and so far I have not had any critter problems. Its main advantage is that it helps keep the moisture at bay.
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
DrEntropy MGB Air filter MG 16
F TR4/4A Replacement air filter for SU HS6 Triumph 6
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
E MGB Oiling foam air filter MG 3
M Cooper's Air Filter on H1 Carbs Spridgets 5
tahoe healey Cooper decal on air filter Austin Healey 2
tahoe healey Original Air Filter Maintenance Austin Healey 4
D TR2/3/3A Air filter Triumph 11
sim air filter box for a DCOE 40 Spridgets 3
B Spacer between rear air filter and carb - BJ7 Austin Healey 11
G Brake Booster Replacement Air Filter Austin Healey 4
G TR6 TR6 air filter element replacements for stock housing Triumph 3
Patrick67BJ8 Denis Welch Air Filter for BJ8 Austin Healey 22
J Air filter help Austin Healey 0
J AC air filter tricks and maintenance Other British Cars 0
fpstude TR4/4A Air Filter Soaked With Gasoline - TR4A Triumph 9
W Air Filter Removal Austin Healey 9
G TR2/3/3A paper air filter for tr3 Triumph 1
D MGB mgb air filter MG 2
davidb AH oiling the air filter Austin Healey 13
M Healey Air Filter Rebuilding Austin Healey 1
B SU Air Filter Mounting Triumph 6
T Breather Tube - Oil dumping in air filter and carb Austin Healey 30
W GT6 GT6 air filter Triumph 3
G Euro carb air filter clearance problems Spridgets 2
Newkie Air Filter Assembly question MG 23
F air filter over ram pipe Spridgets 1
P Air filter securing mod Austin Healey 11
D help...? Air Filter ideas needed...nothing fits! Spridgets 23
N Brake servo air filter Austin Healey 2
D Spitfire Spitfire air filter element Triumph 7
T Air filter options Triumph 3
R k&n air filter p/n for weber dgv on 1500 midget? Spridgets 7
T Metal air filter assembly and/or HS1 carb set Spridgets 0
B Picture of Original Bugeye Air filter Spridgets 3
19_again oil and air filter upgrade options? Triumph 10
S E-Type Air Filter Breather Jaguar 0
tweety foam air filter Spridgets 1
C Su carb air filter Austin Healey 1
Brooklands Air Filter for Stromberg 175's Triumph 3
Stewart Oil for weber air filter MG 4
fmichaels air filter question Spridgets 6
eschneider MGB mgb stromberg re-jet for hi-flow air filter MG 30
Z Air Filter Oils Austin Healey 1
Baz K&N Air filter assbly Spridgets 5
Atrus Air in fuel filter Spridgets 11
Woodie air filter vendor Spridgets 2
Woodie air filter diameter Spridgets 0
