T-Series 5 Speed Transmission
PAUL161
Just ordered a 5 speed from High Gear. 2.98 first gear for the TF. Doesn't take long to make the order up, but possible delay in driveshaft parts to complete the order. HG said they're trying to get the driveshaft problem resolved, hope so, might be well into January before delivery. :rolleyes2:
Mickey Richaud
That'll truly transform your TF - I'm sure you're gonna love it!
The overdrive in my Victor with the MGB engine is great at speed.
PAUL161
PAUL161
Thanks, Mickey, now the wait until I get it will seem like forever. One fella waited 10 weeks before he got his delivery, something to do with the Covid situation, understandable. :rolleyes2:
PigeonF16
I'm new here. Just curious, but what is the story with these older transmissions? My cars will never be show cars, so I don't have a need to keep them original for "value" or "show." I'm pretty sure all the engines and transmissions in the MGAs my dad had are somewhat original, except for swapping a 1500 for a 1600 engine. I don't know why, but the previous owner of the TR-3 said he put a TR-4 transmission in it back in the '70s. Other than catastrophic transmission failure, would there have been a reason to replace the TR3 transmission with a TR4's? I hope your wait isn't too long and you enjoy the new transmission.
Mickey Richaud
Couple reasons, besides failure of the original. One would be the getting rid of an old, non first-gear synchro box and replacing it with one that's fully synchro, which is most likely the case with your previous owner. Another reason is to take advantage of overdrive if the original tranny wasn't so equipped. Drops the rpm considerably at speed, which makes for a lot more enjoyable drive at speed and also is much easier on the engine. And in Paul's case, he gets both benefits with a five-speed conversion.
Oh, and welcome to the party!
PAUL161
PAUL161
With a tailwind, I'll probably be able to get 80 MPH out of it with the new tranny! :driving::arms:
Gliderman8
Putting a 5-speed transmission in my 6 was one of the best upgrades to the car.
I miss Herman… what a gentleman!
PAUL161
PAUL161
From all reports, it shouldn't be too hard to pull the transmission out, to replace it with the 5 speed. It's just a pain as it has to come out from the inside, cross-member won't allow it to be removed from the bottom. Once out in the open, I'll use an engine lift to pick it out. The Smith heater hopefully isn't in the way as the top of the remote is fairly close, if needed I'll have to remove the remote first.
PAUL161
PAUL161
Because I don't trust the bell housing to sump threads, (they're not as snug as they should be) and 33 foot-pounds torque might be a little too much, I'm installing 8mmX1mm Heili coils in the aluminum sump.
Gliderman8
Paul,
You might also check out Keencerts. I used them when I installed some wheel studs.
PAUL161
PAUL161
Thanks, Elliot I have already ordered the Heil coils, should be here in a couple of days, I never heard of Keencerts, I will check on them though. The demo looks good. PJ
PAUL161
PAUL161
Got the Heli Coils and on a test piece of aluminum square stock they work great! I'm waiting for the new transmission to come before I pull the old one, don't want the engine setting on the sump any longer than necessary. PJ
Platinum
Paul, the best argument for the Keencerts is ease of removal. Heli-Coils are a real b**ch to remove if necessary.
...ask me how I know... 😉
PAUL161
PAUL161
High Gear Type 2 price.
I received this from High Gear for the type 2 kit. Type 2 kit doesn't require moving the engine, but does require cutting the rear mount cross bar. and incerting a custom made casting rear transmission mount.
1 MGTF 5 speed conversion kit Type 2. £1325-00 GBP
1 Foord Type 9 gearbox (2.98 first gear) rebuilt. £1650-00 GBP
2 Litre gear oil (Use for warranty) £16-00 GBP
shipping -------------------------------------- £310.00 GBP
Total=========================== £3301-00 GBP
Converted to US Dollars at the time.= $4393.68
drooartz
That pricing seems in line with the costs of other conversions I've seen. A friend of mine did a Datsun conversion in his MGB recently and it was about the same cost. Not cheap, but very worth it.
PAUL161
PAUL161
Drew, I ordered the kit with the rebuilt transmission and the 2.98 first gear conversion on 11/30/21. possibly be here in late January. The driveshafts are specially made by a separate company to adapt to the Ford T-9 transmission and that I think stretches out the delivery. As I understand, these kits are made up after the order is placed. PJ
pdplot
If you have the Tf, you already should have the 4.875 rear end. The TD had a 5.125 which was ridiculous with a new gearbox. You revved like mad and didn't go anywhere.
PAUL161
PAUL161
Forgot to mention, With the newer Type 2 kit, the original trans cover is used.
NutmegCT
Paul - congratulations on the upgrade! Looks like a lot of work to do the conversion, but it'll make your TF more enjoyable. I sure hope you have a car lift in your garage so you can get access!
Tom M.
PAUL161
PAUL161
The transmission has to come out the top Tom, the crossbar won't let it come out the bottom. Engine hoist to lift it out making sure it doesn't touch anything. I really like the fact that the original cover is used as nothing is changed above the floor. All original equipment will be crated, kept together and stored, for now, I'll decide later what to do with it if anything. PJ
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
Cappy Toyota 5 Speed transmission Austin Healey 4
Tullamore BN1 3 Speed Transmission Third Motion Shaft Disassembly Austin Healey 3
M FOR SALE: 280i 2.8 v6 engine and 4 speed transmission for sale TVR 2
PAUL161 Datsun 5 speed transmission MG 10
jhorton3 Rebuild 5-Speed Datsun Transmission Spridgets 19
RickB Saw my new 5 speed transmission today Spridgets 4
B How to identify a Datsun 210 5-speed transmission Spridgets 1
T 4 Speed Transmission in a BN-1 Austin Healey 0
M Datsun 210 transmission 5 speed shift lever Austin Healey 4
A New!!! Gear Shift Knobs for 5 Speed Transmission Triumph 1
AngliaGT 5 Speed Datsun Transmission Spridgets 8
1 5 speed Datsun transmission... Spridgets 34
AngliaGT Rover/Triumph LT77 5 Speed Transmission Triumph 5
Bruce_B %#@#%@ 5 speed transmission - rear mount!!--Help Spridgets 11
gubba TR2/3/3A TR3 B 5 speed Transmission conversion Triumph 0
Louie Mk 2 Auto transmission speed hold Jaguar 2
N 4-speed transmission--popping out of 4th gear Sunbeam (Rootes) 1
PAUL161 Jag 5 speed? Jaguar 5
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
L General MG Five speed MG 6
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G 5-Speed Conversions Austin Healey 15
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
shadowfever Datsun 5-speed info neede Spridgets 5
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
PAUL161 T-Series 5 Speed Road Test MG 25
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
crispy Idle Speed Variation Austin Healey 19
Cappy Toyota 5-Speed Austin Healey 3
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
I GT6 A type OD vs D type - engagement speed? Triumph 3
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
roscoe 5 speed conversion question Austin Healey 9
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
