215 Aluminum Block Buick
PAUL161
What year cars had this engine? What other cars, if any, used it also? My next project, if I ever get this TF done, will probably be a MGB/C conversion. In the mean time, accumulation of a few parts won't hurt. Not sure about the Buick, just asking and open to suggestions. PJ
Mickey Richaud
Here ya go, Paul:
GM 215
Scroll down a bit and read all about it!
Also, check the British V8 website - lots of info there as well.
:cheers:
Mickey
PAUL161
PAUL161
Thanks Mickey! That is some very interesting reading. Seems like quite a bit of history follows this engine. Nice. PJ
Scott_Hower
It's known as a "BOP 215". As in Buick, Olds, Pontiac. I think it was made from 61-64 by GM; used in just about everything, the Skylark being very popular. During a tour of the GM factory where it is alleged a B/L executive tripped over one (literally) Rover bought the rights in 67 and the rest is history. Variants were used in lots of British iron, Range Rovers, SD1s, TVRs. Ted Schumacher at TSI Imports in Ohio usually hsa a few laying around in various states of tune. He used to haul several to Carlisle every year and sell out.
Platinum
They seem to have been fairly well scrounged up around here.
PAUL161
PAUL161
Since finding a 215 is getting tougher as time goes by, what other engines,(V8s), are comparable in size, weight and HP? 289? PJ
Platinum
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] 372hp and the ability to rev to over 10,000rpm [/QUOTE]
UNDER powered? What th' heck are ya lookin' for, Paul?!?! :shocked:
PAUL161
PAUL161
<span style="font-size: 11pt">Rocket boosters Doc !</span> :driving: :devilgrin:
Remember that this is the block that is the foundation of the Rover 3.5 and on.
I have a Rover 3.9 in my conversion.
That being said, I would use a small block Ford (302) if making the choice today. There is a LOT more aftermarket support.
Also....if you're going to do a conversion, PLEASE use an MGB and NOT and MGC!
550,xxx MGBs compared to 9001 MGCs.....and there are plenty of rubber bumpered MGBs available!
PAUL161
PAUL161
<span style="color: #FF0000">Also....if you're going to do a conversion, PLEASE use an MGB and NOT and MGC!</span>
Thanks Rick! I really wouldn't cut up a C to do that. If I ever stumbled across a C, it would be restored back to factory only.
As far as Fords go, my brother in law had an original aluminum bodied Cobra with a 289 Ford in it and it was one wild machine. PJ
billspohn
The 215 is hopelessly out of date. Consider a more modern Rover version or a GM V6.
PAUL161
PAUL161
Bill, I have been giving it a lot of thought along those lines. I just found out that my son has a Olds 215 that needs rebuilding and would give it to me, but I've been doing a lot of reading up on previous conversions and the idea that I could walk into any parts store and buy parts for it, makes me lean toward a more modern engine. I like Fords and have had a lot of dealings with them over the years. Parts availability for the little 289/302 is very good, along with pretty chrome accessories that's easily available for them. Along with the Ford 5 speed, it would be a good combination. Radiator, my son has a radiator shop and builds custom rads for the race crowd when needed, so that's no worry. But,--- I haven't decided yet, as I'm not going to build the car tomorrow. I've got this TF to finish and, if I don't go broke first, that should take another year or so! Notice the,--- Or So! :hammer: :rolleyes: PJ
PAUL161
PAUL161
rick_ingram said:
Go for the V8....go for the Ford 302.
That's what I'm thinking Rick. Like I said before, I am pretty savvy on the Ford engines, but just the carburettor types, not fuel injected. I never did care for Chevy's orange paint color! :jester:
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
T Carroll Shelby Sprite with 215 V8 question? Austin Healey 2
K TR2/3/3A TR3 with a 215 V8? Triumph 17
S Looking for a Rover 215 motor. MG 9
Jim_Gruber MGB Pair of MGBs and 215 V8 Available cheap - Dayton O MG 4
Jim_Gruber Pair of MGB's and 215 V-8 available cheap Dayton Spridgets 0
philman six buick 215's for sale on PDX Craig's list Restoration & Tools 0
R 215 Buick into 79 "B" MG 5
J TR4/4A 215/60/15 Tires on a TR4? Triumph 5
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
B TR4/4A Aluminum head water leak? Triumph 7
maxwedge5281 aluminum fender vents installation Austin Healey 14
JFS Wedge Aluminum Rad Triumph 16
Nunyas what to use on polished aluminum Restoration & Tools 4
Chancevought953 Black welt piping on aluminum surrounds Austin Healey 1
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
S Aluminum wing vents for BT7 3000 Austin Healey 1
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
maxwedge5281 aluminum body parts Austin Healey 15
SherpaPilot TR6 New Aluminum Radiator Triumph 4
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH TR4/4A Aluminum Front Plate from Moss and BPNW Triumph 2
