[ QUOTE ]
[ QUOTE ]
i have to rebuild the tranny i have
[/ QUOTE ]
What makes you think the transmission needs rebuilding - those things are virtually bulletproof! What's it doing?
[/ QUOTE ]
Agreed. Replace the front and rear gearbox seals and the front and side gaskets. Drain the oil and refill with Redline MT90 (pretty sure I was advised to use MT90 instead of MTL, I forget). Replace the nylon bushings in the tower and the switches and flush the breather you're all set.
An impact wrench with the correct socket (1 5/16 ... 1 1/8?) and some long drilled angle iron to bolt up the flange will make short work of removing the tailshaft nut.
