MGB 1973 MGB help Please
If given the choice - and the money was available for either - I'd go stock, or stock with overdrive. Keep it in the family - so to speak.
[ QUOTE ]
i have to rebuild the tranny i have
[/ QUOTE ]
What makes you think the transmission needs rebuilding - those things are virtually bulletproof! What's it doing?
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
nothing but. i think i need to rebuild it before i restore the car to it fullest
I'm not expert - I've only been working on these cars for about a year - but I have learned the hard way that "if it ain't broke, don't fix it."
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
Agreed. Replace the front and rear gearbox seals and the front and side gaskets. Drain the oil and refill with Redline MT90 (pretty sure I was advised to use MT90 instead of MTL, I forget). Replace the nylon bushings in the tower and the switches and flush the breather you're all set.
An impact wrench with the correct socket (1 5/16 ... 1 1/8?) and some long drilled angle iron to bolt up the flange will make short work of removing the tailshaft nut.
well what if it has been sitting for like 20 years in a barn and out in the weather.
[ QUOTE ]
[/ QUOTE ]
Don't fret. Tony had sound advice. Replace the perishable bits (as described above) and it should be fine.
