Here's one of the big pistons...5-1/8" across! When my A&P saw the pic he commented on all the ring gaps being lined up. I would hope they rotated and just happened to be in this position...otherwise the last mechanic was not very conscientious?!? Again, very little wear or carbon.
As with all engine rebuilds, it is essential to keep the parts marked so they can be returned to the same location.
Here are all seven cylinders, stripped down bare. You will notice the number 7 on the lower right has crash damage. I will either need to replace it or attempt to weld it.
And the valves confirm little time on the motor...no carbon build-up at all.
Next the rear gear box comes apart. This is the rear cover. All the gears are mounted to it...the one in the middle his splined to the rear of the crankshaft to drive that crazy mess. I hope I don't lose these pics when it comes time to put it all back together!?!
This is the back of the engine casing. The large gear is actually the inside of the cam wheel. The lifters are all roller lifters, and they ride on 2 cam wheels...one drives the odd cylinders, while the other drives the even. Also of interest is the smooth, round part of the casting. That is the intake manifold! The carb mounts on the bottom, and feeds the circular manifold. Then, tubes lead the mixture to the intake valves.
I will continue the teardown. Once all apart, I will have to clean everything, strip the paint, inspect for damage, repair what I can, and make a list of what I cannot fix. So far I am both pleased and disheartened. Fortunately, so far nothing is beyond repair.
More to follow....
