XJ6 series III front end rattle
dvr
I have replaced outer tie rods, upper ball joints, steering rack bushings. Still have the rattle (dull rattle sound over minor bumps, etc. ). Could this be the inner tie rod ball joints? Any suggestions? Thanks guys.
Deleted member 8987
Shock bushings (upper and lower), sway bar bushings and link bushings is where I'd look first.
Also, make sure the wheel bearings aren't loose.
Car on the ground, lay down by each wheel on a blanket, push up and pull down on the wing, put your hand on bits and you can feel it to pinpoint.
jessebogan
Usually shock bushings. Best of all, easy and cheap!!
LarryK
First thought too! Just as Jesse, TOC, and Steve. Those were the first thing we did in the shop and was a 99% cure. The spongy originals really don't last much over 30K. But, replace with original bushings on top as the harder bushings can pull the metal over time.
J Question about Series III XJ6 Motor in E Type? Jaguar 2
M 87 Series III XJ6 Rough Running Jaguar 16
M 87 Series III XJ6 won't Start Jaguar 16
M 4.2 Liter Engine Serial Number in a Series III XJ6 Jaguar 2
M Alternator or Battery Problem on 87 XJ6 Series III Jaguar 5
M Tricks for Alternator Removal 87 XJ6 Series III? Jaguar 8
wkilleffer Series III XJ6 a/c amp questions Jaguar 1
bmurphy7369 Need some rust repair advice for Series III XJ6 Jaguar 8
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
W XJ6 Series I bumper swap to Series II Jaguar 0
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
D Posi-Rear end in a series 3 Jaguar xj6 Jaguar 12
B Lead on xj6 series 1 / Chevrolet 350 Jaguar 0
V Cd numbers for Series 1 XJ6 or 12. Jaguar 4
1 Performance up-grades XJ6 series 3?????? Jaguar 4
healeyneil series 3 XJ6 toolkit Jaguar 3
eschneider what to look for when buying a '79 series II XJ6 Jaguar 39
M 87 XJ6 Series Three Sunroof Jaguar 2
bmurphy7369 XJ6 Series II Parts Needed Jaguar 11
S XJ6 Series 1 Jaguar 1
R For Sale For Sale 1990 Jaguar XJ6 Jaguar Classifieds 0
E 1996 XJ6 Jaguar 1
V 89 XJ6, How to adjust front camber? Jaguar 2
A For Sale 1986 jaguar xj6 Jaguar Classifieds 0
S XJ6 Mk1 clutch slave question Jaguar 0
SherpaPilot Wiring Harness for XJ6 Jaguar 1
C tachometer for XJ6 Jaguar 0
Marvin Gruber XJ6 engine swap into XK 150 Jaguar 4
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
krswen Question about XJ6 cam covers Jaguar 6
smaceng Help with a XJ6 [sort of] Clutch Jaguar 3
W Removing wiper arm on 74 XJ6? Jaguar 0
B '72 XJ6 Door Seal Installation Jaguar 2
D XJ6 SIII, idle adjustment Jaguar 7
T 10000k HIDs for 96 XJ6 Jaguar 4
D 85 XJ6 brake fluid reservoir leak Jaguar 4
D 85 XJ6 Heater Core Replacement Advice Wanted Jaguar 19
D XJ6 Seat Removal Q. Jaguar 5
D 85 XJ6 No start, coil problem. Please Help Jaguar 11
K 72 Jaguar XJ6 4.2 litre motor reliability? Jaguar 4
CZ_Dave A Redneck Jaguar XJ6 Spotted 9
CZ_Dave A Redneck Jaguar XJ6 Jaguar 2
C Remove/Install New '93 XJ6 Door Lock Actuator Jaguar 0
C 1999 xk8 steering wheel swap out '93 xj6 Jaguar 3
W Removing windows in 74 Jaguar XJ6 Jaguar 1
R Jaguar XJ6 Door Locks Jaguar 8
B 85 jag XJ6 improve it's performance ? Jaguar 4
eschneider xj6 purge valve / air bleed valve Jaguar 4
dklawson Early '80s XJ6 Speedometer Transducer? Jaguar 0
M 1985 XJ6 Drivers door lock Jaguar 5
