waterpump question
DougF
You might have a couple options. A. You can smash it off with hammer and go out and purchase a new pulley. B. You can try a gear puller with more than two paws to gently see if it will move. C. Heat the waterpump shaft and cool it. Expansion/contraction will often break the part free, then try the puller again. If these ideas do not work, try some body else's idea or refer back to A.
Geo Hahn
Here is the tool I made for pulling the pulley off TR3 & 4 pumps. Works easy and smooth w/o mashing the radiator:
Knocks down to no space at all so I carry it with me on long trips (since I also carry a pump on those drives).
Those are 3/8" bolts. Let me know if you want specifics (bolt lengths etc).
K Elan waterpump Lotus 2
R Waterpump quality Austin Healey 8
B Gen/waterpump belt Austin Healey 13
W waterpump to radiator hose quandry Jaguar 1
B Waterpump vs radiator? Spridgets 2
B Spitfire Spitfire Waterpump Pulley???? Triumph 1
B Midget 1500 Waterpump Pulley Spridgets 0
regularman Is it possible I have the wrong waterpump? Spridgets 21
Webb Signs of a Broken Waterpump? Triumph 10
Luke_Healey How to make my own 1098 radiator-to-waterpump hose Spridgets 19
G TR6 TR6 waterpump Triumph 12
DrEntropy BMW 318i waterpump R&R? Other Cars 5
mgb4tim Wedge TR7 Waterpump housing Triumph 8
SCguy Waterpump housing leak? Triumph 3
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
