MGB Replacement starter
Platinum
The ring gear in our '64 had been giving me fits, starter engagement due to wear on the ring gear became a game of "Starter Roulette". On a day late in November the engine failed to start on first partial spin, subsequent efforts unsuccessful, until the Bendix JAMMED in the gear. The last straw. Ordered a torque-reduction starter, engagement from the front side of the ring gear. Took a bit of fettling, on my back on the concrete driveway where the car had been parked last. Did most of the task from the top side, dizzy, oil cooler lines and dipstick removed, then removing the original Bendix starter and lowering it out the bottom. New one placed from the top, upper bolt went in with no issue. Had to use the "Braille" method of fiddling the bottom bolt into the replacement starter and getting the nut to start. Then it became a contest of patience; only tool to fit the space where the nut could be tightened wouldn't allow anything but an open-end wrench and that only an eighth of a turn before flipping the tool 180° and reacquiring the nut by feel to advance another eighth of a turn... BORING!!
After all was in place and battery reconnected, the thing spun up sounding like an APU for an F-4! But the engine didn't start. Sat too long outdoors, no spark. Dizzy out, points cleaned with file, rotor contact brass cleaned with #600 wet-or-dry, Dizzy reinstalled. Engine turned by hand to set timing mark, static timed the dizzy, hit the starter and VROOM!!!!
If any decide to make this starter change (and I will highly recommend it), do it on a lift or where you can access the underside of the vehicle easily.
When the clutch needs replacement a new ring-gear will be fitted.
NutmegCT
Good to hear you started 2021 with a challenge.
:jester:
Say, any idea why the engine wouldn't start at first? Seems two months wouldn't bring the need to do all that ignition "freshening".
Tom M.
Gliderman8
About 2-3 years ago I had a similar starting problem on my 6. As it turned out, it was the ring gear. A $30 replacement part but as you know, I had to pull the transmission out to install it :censored:.
Prior to learning it was the ring gear, I bought a gear reduction starter. After replacing the ring gear I decided to install the gear reduction starter (though it wasn't needed). I am so glad I did; it's half the weight, and it spins the engine with vigor.
A PITA job indeed doc but now it's done!
Platinum
Done a number of TR-6 transectomys, no fun but not as much work as with an MGB. You had to remove seat, carpet and tunnel, an MGB needs the engine and trans pulled out of the car as a unit. I'd rather do three Triumph clutch R&R's than one MGB. :wink:
:jester:
Tom M.
I'm sure it was the "fuzzy" points, from sitting outside for a couple months without being started. Ordinarily a couple half-down applications of the accelerator pedal ( it has a DCOE 40mm Weber) and it would light off with half a rev with the starter. When the Bendix of the original starter cramminated, it was the end of my patience. On close inspection of the old starter after the replacement, found the bushings of the starter worn as well.
Gliderman8
Just found this pic I took showing the size (and weight) difference between the OEM starter and the modern gear reduction starter.
Platinum
The weight difference was what impressed me.
The battery terminal on the new one is in a bit of a dangerous spot in an MGB, in that the lower clip securing the dizzy cap could drop down and make contact with it. I made up a new cable to run from the remote mounted solenoid to starter and used the rubber boot furnished with the new unit to hopefully preclude any such problem.
Platinum
Hi mate, i hope you are fine.
take a look to this video it may help you.
Had you actually read the original post and subsequent ones in the thread, you would notice the job was DONE already. No "help" necessary.
This video addresses issues with "modern" vehicles, it is certainly not specific to MG's.
W Starter Replacement Saga Jaguar 5
jsfbond GT6 GT6 starter replacement? Triumph 10
HealeyPilot Starter motor replacement - Mini Cooper S British Motor Corp 3
George Zeck Replacement Starter?? Spridgets 2
S TR6 TR6 Starter Replacement Tips Triumph 3
johnrip Wedge TR7 starter replacement question Triumph 2
M Starter replacement MG 10
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
WHT Rocker Arm Shaft Replacement Austin Healey 21
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
D Engine replacement. Rover / Land Rover 0
EWD TR6 Dash Pad Replacement Triumph 3
R TR6 fan shroud replacement Triumph 5
C Replacement wheels Rover / Land Rover 1
B TR4/4A Floor pan replacement Triumph 4
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
M General MG Midget MK1 windshield replacement MG 2
M TR6 Replacement Steering Rack ? Triumph 7
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
A TR2/3/3A TR3-A replacement top Triumph 7
