TR2/3/3A Oh no, not again
deuce
Ok guys.. I found another part in the bottom of a parts bin. The last one required the tranny, clutch and flywheel removal..for a 5 second pilot bushing install. So good news only, please:friendly_wink:. 20200524_162639[1].jpgHope you all had a nice, safe weekend
CJD
That’s the lift eye that goes on the rear of the head. I think it sets under 1 head bolt and 1 manifold bolt. Not all cars had them.
deuce
O man..thanks. That's good news indeed! It will go in the 'maybe later' box, though I was wondering about that lift eye. I had heard about it and about it not always being there. Well, I have it for the next time I pull the engine...hopefully never. Thanks again
Geo Hahn
Mine was a bronze bushing that had fallen out of the end of the starter. Slow cranking had be confused for a bit until I remembered what I had found on the garage floor mid-assembly.
CJD
Just remember that if you decide to use it, it takes a slightly longer rear head stud.
Graham H
I think it was an optional extra, if it was on your engine you should already have the longer head stud?
Graham
deuce
STeve 1958..that's funny. I bet that drove you about half nuts. I don't know why I thought I was the only one. I'm in good company. As far as using the part, if I was to use it, the engine was rebuilt so I'm not completely sure if a longer head bolt was used, but it seems it would just replace the flat washer on the bolt at the head and at the exhaust manifold. I don't think I will install it though. Would it hurt to undo the head bolt? Aw..don't need it. Thanks all
K TR2/3/3A Side view mirrors again Triumph 8
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
G MGB ugh.....the fuel gauge went to *** again! MG 8
L T-Series Spark plugs again ? MG 2
G Really nice to see some people are posting here again! TVR 8
K TR2/3/3A Wing mirror replacement again... Triumph 0
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
A Drum Brakes Again Austin Healey 18
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Editor_Reid Chagrinned Again Spridgets 23
waltesefalcon The Miata rides again Other Cars 11
TomMull Copper nickel lines again Restoration & Tools 0
B TR2/3/3A It runs, again Triumph 3
JPSmit Ms Triss is home again. Spridgets 12
DocDup1 TR4/4A On The Road Again! Triumph 4
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
Rut TR4/4A Stuck clutch, again Triumph 19
TomMull TR2/3/3A 1st gear again Triumph 3
tr6nitjulius General TR At it again Group Therapy! Triumph 0
T General Tech Once again, check the easy stuff Triumph 2
drooartz Carried home on my shield... again Spridgets 17
AngliaGT Healey Fiesta - For Sale (again) Other Cars 4
nichola TR6 Grrr, again, this time brake lines Triumph 18
Lin Thermostat and blanking Sleeve question again Austin Healey 7
K TR2/3/3A The steering box again? Triumph 9
T Spitfire Overdrive again and again... Triumph 5
Nelson Oil leaks again Spridgets 1
tr6nitjulius Someday we'll do it again! Austin Healey 8
pbraun On the road again Spridgets 15
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
K TR2/3/3A Steering box fluid again.... Triumph 2
K TR2/3/3A Speedometer Error Again Triumph 8
HealeyPassion AH EFI build... again Austin Healey 41
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
S TR2/3/3A Carburetors again, and again, and again Triumph 14
K TR2/3/3A Fuel Gauge again.... Triumph 11
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
Bob_Spidell Camber Adjustment [again] Austin Healey 24
MadMarx Wedge The IMSA TR8 is ready to go again Triumph 7
S TR2/3/3A Carburators..again. Triumph 9
tahoe healey Castrol oil again Austin Healey 37
M TR4/4A Surrey Top fitment question again Triumph 1
tahoe healey Tire pressure again Austin Healey 59
K TR2/3/3A Brake Calipers again. Triumph 1
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
HighAltitudeTR3 TR2/3/3A Doesn’t want to start up again after a ride... Triumph 24
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
DerekJ Jack Rawles wins again!! Austin Healey 1
