TR2/3/3A Bubbling in brake reservoir. No pressure in lines
BassettBrits
I recently purchased a 1961 Tr3A. The brakes do not work. I was trying to bleed them today. Very little if any pressure in the lines. It looks like the master cylinder is new. When I pump the brakes, it goes to the floor. The telltale problem must have to do with something going wrong with the master cylinder. The brake fluid reservoir bubbles and fluid will shoot up when the brake is pumped, like fluid is going back in the reservoir.
mrv8q
Very easy to rebuild the MC. Check the rubber brake lines as well, I believe there are three.
TR3driver
Great Pumpkin - R.I.P
Do you get fluid and bubbles in the reservoir when pressing the pedal? If so, definitely a bad MC.
But if they only happen when you release the pedal, you may have some other problem. If the MC is full of air, it can seem like it doesn't work, when in reality it's just compressing the air.
DavidApp
Have you tried using a vacuum bleeder?
Put a good gob of grease around the bleeder nipple thread to get a good seal and see if you can pull fluid into the system.
I did have a brand new MC which turned out to have a problem. Not like you describe but it did not work right.
David
B
BassettBrits
I don't seem to get bubbles but fluid pumping back into the reservoir. I think I'll bleed the MC and if no help, I have a replacement MC.
Thanks for the help.
Graham H
I had a similar problem with a new MC it just would not bleed all the air out, got the original rebuilt and had no more problems
graham
HighAltitudeTR3 TR2/3/3A Fuel bubbling at glass filter bowl Triumph 4
R Head stud bubbling oil Austin Healey 23
R Aluminium and paint bubbling issues Austin Healey 12
Z bubbling coolant bottle Triumph 7
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
B Rear Brake Cylinders Austin Healey 4
K TR2/3/3A Brand new brake caliper question... Triumph 8
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Chrisc9 TR6 TR6 brake light Triumph 6
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
kodpkd Disc Brake Pad Installation Austin Healey 11
