TR2/3/3A manifold studs..locktite or antiseize
deuce
Hi Folks.. getting ready to install the manifolds on my tr3a with all new studs. So, do I want the studs to stay in or come out? Thanks
Sarastro
I'd put a little antiseize on them. I don't like using loctite on something like this--the blue stuff won't take the temperature, and if you use the red, high-temperature stuff, you'll have quite a job if you ever need to replace the stud. If the stud is screwed all the way home, and the nut is properly torqued, it won't come loose.
bobhustead
The purpose of torquing is to stretch the fastener so that enough pressure is applied to the mating surfaces. It is not to seat threads. You only need to torque the nut.
Sarastro
Yes, Bob's quite right. Also, since you are tightening it against a rather thick, soft gasket, it's not a bad idea to retorque the manifold nuts after a few hours of use.
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
D BT7 head manifold studs Austin Healey 7
D TR4/4A wobbly exhaust manifold studs Triumph 17
S TR2/3/3A exhaust manifold with rusted and broke studs Triumph 5
Rut Manifold studs Spridgets 10
Rut Manifold studs, nuts, keepers Spridgets 13
PeterK Repairing cast iron manifold studs Triumph 16
Andrew Mace Post-War Other Herald: thoughts on manifold flange studs and nuts Triumph 5
J intake manifold studs Austin Healey 5
2wrench Opinion on intake and exhaust manifold studs Triumph 5
2wrench Exhaust manifold studs, Brosky Triumph 4
MGTF1250Dave TR2/3/3A TR3 Intake Exhaust Manifold Studs Triumph 9
Lin intake manifold to carb studs Austin Healey 11
Morris Manifold studs MG 8
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 4
C LCB header with 1500 single carb inlet manifold Spridgets 1
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Failed intake manifold gasket? Triumph 2
Carlbanan56 MGB Manifold plug MG 5
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
V MGB Replace late intake manifold angled breather with early model straight? MG 1
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale- TR-6 Intake Manifold Triumph Classifieds 0
M WANTED......Cannon Inlet Manifold Triumph Classifieds 0
9 For Sale: Thermocarb - complete setup including special manifold Austin Healey Classifieds 1
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
Ripper01 For Sale TR6 '69-72 Intake Manifold Stanpart V3108 Triumph Classifieds 0
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
steveg TR6 Fixing the intake manifold Triumph 8
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
B AH Spares Fast-Flow Fuel Manifold Austin Healey 2
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
B AH Spares Ltd. Inlet Manifold No. FUL 340 Austin Healey 2
Michael Oritt Intake manifold question Austin Healey 11
Michael Oritt Manifold Gasket Dressing/Sealant Recommendations Austin Healey 6
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
steve00136 MGB Intake manifold alignment MG 4
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Zitch For Sale TR-4A exhaust manifold Triumph Classifieds 0
