Results 1 to 6 of 6
Thread: Wiper Motor bracket
  1. #1
    Join Date
    Aug 2019
    Location
    Cherokee Village AR
    Posts
    52
    Thanks Thanks Given
    Thanks Thanks Received
    2
    Thanked in
    Wiper Motor bracket
    TR3B
    In need of a wiper motor bracket for my TR3B, mine is pitted beyond re-installation.
    I replied in Triumph classifieds but thought I'd post here with some questions.
    Anyone know how to get to the mounting area for the bracket ,next to the Master cylinders, for this item? It looks like fabrication may be the only answer for me so far...
    This project is not in my shop manual.
    The mounting ears had nut keepers and the mounting bolts are accessible but the keepers have faded with time.
  2. #2
    Yoda martx-5's Avatar
    Join Date
    Jul 2002
    Location
    Kings Park, NY
    Posts
    6,612
    Thanks Thanks Given
    8
    Thanked in
    Re: Wiper Motor bracket
    Besides the two screws up top, there is one nut that screws onto a stud on the bracket next to the master cylinders. Access to that nut is from underneath, up by the pedal box.
    Fabrication is probably the best way to go.
    Art
    '58 TR3A TS236xxL
    '92 Mazda Miata -- Supercharged
    '07 Mazda RX-8
    '11 Mazda CX-7
  3. #3
    Join Date
    Aug 2019
    Location
    Cherokee Village AR
    Posts
    52
    Thanks Thanks Given
    2
    Thanked in
    martx-5
    Thank you for the response. The stud is OK, the ears that the two holes in the bracket bolt to, on the car, are in bad shape.
    I may have to fab the bracket also.
    I've seen pics of new or restored brackets here and there but none for sale....
  4. #4
    Join Date
    Jul 2002
    Location
    Kings Park, NY
    Posts
    6,612
    Thanks Thanks Given
    8
    Thanked in
    I guess that you are talking about the two caged nuts that the screws go into. I just put my car up on the lift to take a look. I can see the forward most caged nut under the wheel well. It looks like if you remove the mud guard piece you should be able to access the rearward caged nut. You can replace the caged nuts. They are welded on, but if you can cut them off, you can always pop rivet on new ones. I did that with some of the caged nuts that didn't allow access to weld. Doesn't look like there is such great access underneath...might be better off removing the front wing.
    Art
    '58 TR3A TS236xxL
    '07 Mazda RX-8
    '11 Mazda CX-7
  5. #5
    Great Pumpkin - R.I.P TR3driver's Avatar
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,552
    Thanks Thanks Given
    8
    138
    Thanked in
    Did you contact Marv Gruber? I'll bet he's got a pile of them. I'm sure I've got several myself, but not where I can get to them easily.
    Randall
  6. #6
    Yoda Marvin Gruber's Avatar
    Join Date
    Jan 2003
    Location
    Florence, Al
    Posts
    3,075
    Thanks Thanks Given
    1
    5
    Thanked in
    Just saw this. Yep, should have a couple good ones off. Just pm your email address for pictures of bracket.
    Marv
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
