Results 1 to 7 of 7
Thread: Proper ring gaps
Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Jedi Hopeful sundown's Avatar
    Join Date
    Mar 2012
    Location
    rutland vt
    Posts
    196
    Thanks Thanks Given
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    Proper ring gaps
    Hi, I recently purchased Hasting ring set (standard) from Moss.When I went to check the gap in the cylinder they were at .022. I thought you would have to file them to manual spec gap.I installed them, I read that the gap is better off big than too tight. My question will there be issues because of this. I also installed new connecting rod bearings.
  2. #2
    Yoda poolboy's Avatar
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,726
    Thanks Thanks Given
    14
    14
    Thanked in
    Re: Proper ring gaps
    That's about twice as wide as recommended, right ?
    DRIVE 'EM IF YOU GOT 'EM
  3. #3
    Join Date
    Mar 2012
    Location
    rutland vt
    Posts
    196
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Yes it ism. The rings came to me like that the box was labeled standard size?
  4. #4
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,254
    Thanks Thanks Given
    7
    104
    Thanked in
    Too big is better than too small; but correct is better than wrong. Specified end gap is .010" to .015"; at .022" you would be starting with rings that are, in effect, already worn. Probably not too serious at first, just a little loss of power, higher fuel consumption, and maybe a bit of oil consumption. Should run fine other than that.
    Randall
  5. #5
    Join Date
    Mar 2012
    Location
    rutland vt
    Posts
    196
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Thanks TR3 driver. I can live with less power. I just want to do some cruising before it gets too cold. Haven't drove it all summer.
  6. #6
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,726
    Thanks Thanks Given
    14
    14
    Thanked in
    Have you measured the actual cylinder bore ?
    The reason I ask is 25k miles ago I went back with new County brand pistons STD size into cylinders honed with a 3 inch Flex Hone and the standard size Hastings ring gap wasn't much over 1/100"
  7. #7
    Join Date
    Mar 2012
    Location
    rutland vt
    Posts
    196
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Hi poolboy, yes I measured the bores there is about +.005 taper from standard bore dia. I'm thinking that would be the reason for the larger gap. I did hone the cylinder out to get the cross hatch marks.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
