Results 1 to 3 of 3
Thread: MGA turn signals
Discussions of MG Sports Cars
  1. #1
    Join Date
    Jul 2006
    Location
    new york, usa
    Posts
    8
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    MGA turn signals
    Need help on getting front turn signals to work on my 1957 MGA. Ran over metal debris on the road and it cut the wires for my right front wiring. Connect the obvious cut wires but turn signals do not work. Only have two wires competing out of parking/turn signal, how do I connect the ground. Also cannot find the ground on the right front side. I feel the ground is the problem but any other advice is appreciated. Thank you
  2. #2
    Great Pumpkin DrEntropy's Avatar
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    33,049
    Thanks Thanks Given
    26
    66
    Thanked in
    Re: MGA turn signals
    Ground should be established through the chassis. No "ground wire" per se. To determine if the bulb holder isn't getting good connection, run another wire from a solid point on the chassis to the bulb holder shell and see if the lights come on.
    '64 MGB, '67 Lotus Elan S-3 DHC,'69 Lotus Elan +2
    '78 Alfa Romeo Spider-undergoing surgery: O=\*/=O
    '84 300D Turbo-"Diesela"-Now my Daily: Oo|≣|oO
    '02 Toyota Camry- SWMBO's 'new-to-her' Daily. <sigh>
    Chaos & Mayhem PTY, LTD..C.I.O. & Floor Sweepervisor
  3. #3
    Join Date
    Jul 2006
    Location
    new york, usa
    Posts
    8
    Thanks Thanks Given
    Thanked in
    Two wires coming from the turn signal on right hand side. When I turn the lights on one wire is hot the other wire no power. I disconnected the no power wire to test and it did not effect the light being on. When I switched the turn signal on my test light connected to the non power wire blinked like a turn signal. When I reconnected the wires no turn signal light blinked but the test light still blinked. Since the left turn signal also does not work I don’t think it’s the bulbs. Also can’t find the ground doesn’t seem to be on the right side. Difficult to get at because of the radiator etc. any suggestions greatly appreciated.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
