Results 1 to 6 of 6
Thread: Why didn't somebody tell me about this before
Discuss general restoration and car care topics (paint & body, upholstery, woodworking, etc) as well as tools.
Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,759
    Thanks Thanks Given
    9
    Thanks Thanks Received
    17
    Thanked in
    I've been rounding square plug and bolt heads using crescent adjustable, open end, box end wrenches and 8 and 12 point sockets for sixty years. Why didn't anybody tell me about this:
    Take 2 sockets of the same size and matching a long nut used for connecting ready rod and available at any hardware store. In my example I used two 7/16 sockets with 3/8 drive. Line the sockets nose to nose with the long nut (7/16 OD in my case) in between and use the 3/8 drive end on the square plug or bolt and the other on the ratchet. You could also use a piece of hex stock between the sockets. Live and learn.
    The tool is limited to the socket drive sizes, but 1/4, 3/8, and 1/2 take care of a very high percentage of the square headed fastenings we'll encounter with our LBCs. The masking tape holds the sockets together on the nut. Live and learn.
    Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  2. #2
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Floe Ice, Antarctica
    Posts
    6,409
    Thanks Thanks Given
    27
    Thanked in
    Re: Why didn't somebody tell me about this before
    Probably didn't tell you because we buy square drive sockets to do the job.
    That one is a tad over five bucks. You buy two sockets for five bucks apiece, then weld them together, and this is cheaper...and the weld won't fail.
  3. #3
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,552
    Thanks Thanks Given
    8
    138
    Thanked in
    Besides which, the most common square heads I deal with are not 1/4, 3/8, or 1/2. Eg, stock transmission fill plug is 7/16".
    Randall
  4. #4
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,759
    Thanks Thanks Given
    9
    17
    Thanked in
    Hey, the sockets are already in the toolbox, the nut to join them is less than a buck, there is no welding and I have a 7/16 square socket and a box end also which I use at least every other year. And I certainly didn't mean to suggest that this would change the way you do business. Actually kind of sorry I mentioned it.
    Tom
  5. #5
    Obi Wan LarryK's Avatar
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    2,054
    Thanks Thanks Given
    20
    Thanked in
    Example: My nephew complained his car squirt gasoline all over him when he changed the fuel filter. I asked him why did he not eliminate the fuel pressure by releasing the schrader valve on the fuel line. He said, " No on told me!" I said, " you did not ask!"
    Larry K
    58 Jag 3.4 MK 1 auto under restoration, 57 Jag 3.4 MK1 manual (parts car),
    03 Cooper S, 2011 Cooper S Countryman, 2011 Land Rover LR4 HSE LUX, 1964 Valiant V200
    Also had , 68 Cortina 1600E, 64 Spit 4 & 80 1500, 73 GT6 3, 71 XJ6, 79 XJ6, 86 XJS V-12, 53 XK120 OTS.
  6. #6
    Administrator
    Join Date
    Dec 2000
    Location
    Turn left at Albuquerque
    Posts
    24,415
    Blog Entries
    7
    Thanks Thanks Given
    62
    105
    Thanked in
    Actually a pretty clever solution to use in a pinch.
    “The smallest act of kindness is worth more than the grandest intention.” - Oscar Wilde
  7. The Following User Says Thank You to Basil For This Useful Post:
    TomMull (05-11-2019)
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
