MGB 1980 MGB No rear brakes after replacing MC & booster
RickB
I replaced the Master and the booster last weekend on my '80 MGB.
The front brakes bleeding went great, no trouble at all.
The rears - nothing. No fluid comes out when the bleeder is opened.
I'm pretty sure others have experienced something like this so what am I doing wrong?
Possible problems:
I did not bench bleed the MC.
All I did with the PDWA was remove it from the old MC and install it in the new one.
I didn't know about adjusting the rear brakes until they were locked up before bleeding so I didn't do that.
Next time I get under there, this weekend, I'll adjust the back so the wheels lock up before I try to bleed them.
Anyone got any great ideas I'd really like to hear them.
Deleted member 8987
You need to bench bleed the master.
That said, you can do it on the car now that you are installed.
Rags, water handy....and two people.
Have your assistant pump up the master, then open the pipe for rear brakes at the master, see if you have any fluid or air spitting.
Close, do it again.
If you get fluid under pressure after a half dozen strokes, now you can bleed back.
If not, pull the master and bench it. I have those little plastic fittings and nylon pipes to bleed back into the reservoir.
Reason for rags and water....if DOT3 or 4, brake fluid will eat paint...and water will neutralize it. Flush it all off.
PDA....is 1980 one of those that shifts the shuttle full over and blocks the dead side?
If so, you may need to centre the shuttle.
Bob Claffie
On my '76 there was a proportioning valve / switch on the drivers inner fender wall. The directions I have seen require you to back out the electrical switch 3 1/2 turns from that device to allow fluid to move to the rear. Not sure on the newer cars but worth a look. S/B covered in the shop manual.
How old are the rubber lines? My front ones collapsed once and locked up the front brakes.
RickB
RickB
None of the above, but thanks for trying. :wink-new:
I bought a vacuum bleeder from HF and this morning got out there and used it.
Now my brakes are awesome!!
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
A MGB 1980 MGB MG 3
P MGB 1980 MGB carb and oil questions MG 3
Russ80MGB MGB 1980 MGB - No power MG 16
P MGB 1980 MGB Modified Intake Manifold MG 7
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
H MGB 1980 mgb no power from ignition switch MG 23
C MGB 1980 MGB Roadster Tyres UK MG 0
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
M For Sale 1980 MGB for Sale MG Classifieds 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
S MGB 1980 MGB quick question MG 2
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
kyreb1862 MGB 1980 MGB Timing Issue MG 5
Tinkerman MGB 1980 MGB wiring diagram help MG 6
Hoosier MGB 1980 MGB rebuild project....A little more help nee MG 4
Hoosier MGB 1980 MGB Suspension Issue MG 3
M MGB My 1980 MGB [Need some help please!] MG 28
Hoosier MGB 1980 MGB Trunk Lid MG 2
Hoosier MGB 1980 MGB Tail Light Chrome Trim MG 10
M MGB 1980 MGB LE or not?? MG 6
N MGB Question about ignition wiring unique to 1980 MGB MG 15
T MGB 1980 MGB 1800 Motor Color MG 6
D MGB 1980 MGB Roadster . . . Restoration Progress MG 32
K MGB 1980 MGB Seat Colours? MG 2
C MGB Console tunnel - 1977 - 1980 MGB MG 5
JamesWilson MGB-GT New 1980 MGB GT for sale.... MG 9
P MGB 1980 mgb fuel pump MG 3
C MGB looking for 1980 MGB limited edition informaton MG 13
M MGB WILL A 1973 MGB STEERING WHEEL FIT ON A 1980 MGB MG 0
M MGB Shakes at about 3000 RPM 1980 MGB MG 5
T MGB 1980 MGB heater blower motor MG 1
T MGB Heater blower motor for 1980 MGB MG 2
I MGB 1980 mgb heater box MG 2
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
BobHaskell MGB 1980 Catalyst sticker MG 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
