Spitfire 1980 spit.. 34000 miles unbelievable
Duane3
Hello all.. hope all are well.. you are going to like this one..I had to change my tranny oil.. no big deal..done it 100s of time .. building Harleys and whatever,, this is my 3rd spit had a 65 and a 78,, got hit broadside in my 78 ,,guy was going 40 miles an hour,, and i lived..anyway so I get my big belly under the car and take plug out no big deal.. plug came out fine,, drained it then started to put the plug back in.. it would go only half way,, thought ok just a little burr,, not so.. that SOB plug would only go in half way.. so baffled I get a tap to check the threads.. tap went in just fine..so tried it again no way,, half inch drive,, remember this plug came out easy and it was not cross threaded..I was sure.. put tap back in no issue,, ordered new plug,, same thing half way and that was it,, so I got ****** and went and bought a regular plug with the same thread ,, got it in to about an 8th of an inch.. it quit,,man I am ballistic something so simple.. the threads were straight not pipe type so was the plug.. anyway I put the plug in that I bought which does not have a magnet,, but I got it.. I said self it is going to go or It will just stripe out.. well went to the 3/4 drive and got it.. man i still cannot figure it out all threads were fine..gremblins I guess any body else??
Geo Hahn
So you finally got it in but had to use a ¾" drive to get it to go? If something was wrong in there (and I suspect there was) I don't think this fixed it. Next oil change may reveal more info.
FlyingCat
I'm in the process of rebuilding an '80 Spitfire that was pretty much in pieces when I got it, so I have to replace a lot of bolts and nuts. I can generally measure for what kind of bolt or nut I need using my nifty thread guage, but there is no guarantee that a bolt or nut will actually work. Some are just a cat's hair off. Sometimes it's the new bolt that just isn't quite right. I've found differeces in the bolt bin at my local hardware in seemingly identical bolts. Go figure. Other times... who knows? It could be that the threads have gotten hot over the years and have "warped" just a little. If your car was in an accident, it could have shifted something. Once you got the original plug out it allowed the hole to shift. Mind you, I'm guessing here. Just to say, I've run into those issue with my '80 Spitfire, too. Hope that helps.
Duane3
Thanks alot,, never run into this before,, done alot of wrenching,, beats the **** out of me,, i went and got me a bolt with washer and it went in tell about 8th inch then quit with a half inch drive,, sooo got ****** and got my 3/4 inch drive and said you are going to go or break.. then just take it to the shop to fix well I got i,, and it is tight,, it is staying there ,, it has no magnet but oh well ... I will just add if I think it needs some ,, do not care if I over fill,, got a small leak in one of the seals so the engine will have to come out thne do it all clutch seals and whatevre,, hey thanks alot !!!!
FlyingCat
You're welcome. My Spitfire set a long time, too. It's got 39,000 miles on it, but it hadn't run in over 25 years until I got hold of it. I've found that if what's wrong could be one of three things, then it's all three. My next project is replacing both lower wishbones so I can reattach the anti-sway bar. Hey, I wanted a project, and I got it!
Duane3
I do not know what it could be,, it all check fine no burrs, good threads for both.. for the miles I put o it that plug will not be coming out anytime soon.. never had this happen on anything before,, plug cam out with my fingers,, but it just would not go back all was checked.. no cross treading or anything,, its british ,, ordered new plug same thing,, so it is what it is..
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
A MGB 1980 MGB MG 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
P MGB 1980 MGB carb and oil questions MG 3
Russ80MGB MGB 1980 MGB - No power MG 16
P MGB 1980 MGB Modified Intake Manifold MG 7
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
H MGB 1980 mgb no power from ignition switch MG 23
C MGB 1980 MGB Roadster Tyres UK MG 0
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
BobHaskell MGB 1980 Catalyst sticker MG 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
M For Sale 1980 MGB for Sale MG Classifieds 2
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
S MGB 1980 MGB quick question MG 2
RickB MGB 1980 Starter Relay & running problems MG 14
K 1980 Jaguar paint colour.... Quartz Blue? Jaguar 2
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
Got_All_4 Wedge 1980 TR7 PI cutting out Triumph 4
U Spitfire Lighting issues on 1980 Spitfire Triumph 2
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
N "Ole 19" Freddy Baker 1980 win article?? Jaguar 1
1 1980 Panther Lima restoration project Other British Cars 11
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
J Wedge Rear Brake Drum 1980 TR 7 Triumph 5
AngliaGT .1980 Honda Accord Spotted 4
S Wedge 1980 TR8 BULB Triumph 3
L Advice for cleaning/painting 1980 rubber bumpers MG 8
Got_All_4 Wedge 1980 TR7 Fuel injection questions Triumph 17
AngliaGT 1980 Bonneville T140 British Motorbikes 9
A Wedge 1980 TR7 Brake master Question Triumph 5
kyreb1862 MGB 1980 MGB Timing Issue MG 5
Got_All_4 Wedge Drove a 1980 TR7 today PICs Triumph 16
W Spitfire 1980 Spitfire Coil Spring Replacement Triumph 2
Got_All_4 Wedge Going to look at a 1980 TR7 on Thursday Triumph 43
Tinkerman MGB 1980 MGB wiring diagram help MG 6
W Spitfire ZS carb on 1980 Spitfire Triumph 11
Gafirema California Emissions + 1980 MKIV 1500 Triumph 251
