Who supplies Stainless Steel lines for clutch?
Norton47
Hi All
Getting ready to do a clutch remove and replace and trans/OD install.
I thought I saw a post where someone mentioned installing a stainless steel (braided?)line for the clutch system.
Has anyone done this?
Is the line available as a part or must it be made up?
If someone has done this before what fittings where used?
I am still driving mine and loathe to break into the system to figure out the fitting type.
These type stainless steel braided lines really help on motorcycle hydraulic brakes, I would think they would be a good application here also.
DNK
Will be useful especially if your line is original. The big 3 all have them and you can also pick them up at speed shops and on line. The fittings someone else has the answer to.
martin_burtt
Member
I bought a stainless steel clutch line last year from the same ebay seller as listed above (NFI). Item was exactly as described and easy to install. All fittings were in place and it was a straight replacement for the existing (and leaking) plastic hose.
N
Norton47
Thanks
Ordered one from TSI same price as ebay.
TR4nut
Typical brand is Goodridge, they sell separate hydraulic lines, as well as complete front and rear lines. I haven't installed them yet, but on inspection they are nice.
Randy
davidk
The upper, steel line is also available in stainless steel thru classictube.com. Unfortunately they have a 4 week lead time.
YankeeTR
These can be made pretty easily in your home shop. Earls, Russell and others sell everything you need to make your own. I'm not sure how much you'll save since I haven't used any AN lines and fittings for several years. But I always made my own when fabricating race cars.
BTW...I may get static for this but I really don't see any reason to use stainless braided hose on a street car. It does firm up the pedal feel on the brakes because it doesn't deflect like rubber. But I've never really seen any big advantage...except that they look pretty and, in some cases, may actually be cheaper.
Brosky
Dave at the Roadster Factory is back to making the upper steel lines again. Pre-bent perfectly, they fit just right.
Moss says that theirs are pre-bent, but they are not. And theirs is more expensive too!
YankeeTR
BritBox said:
"But I've never really seen any big advantage...except that they look pretty and, in some cases, may actually be cheaper."
There you go. Brake system bling!
Roger on the bling....
The main problem is I'm a grumpy old bastard....
D Body work finishing supplies source. Restoration & Tools 0
60TR3A Who Supplies Original Paint Colors? Austin Healey 12
I Bugeye spares supplies for a cross country trip? Spridgets 13
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
Guido36 Stainless Steel Bumpers Austin Healey 5
B Stainless Steel Exhaust System Wanted Austin Healey 5
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
7 For Sale Stainless trim for Herald Convertible top. Triumph Classifieds 0
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
G For Sale Stainless Steel TR6 Bumpers Triumph Classifieds 0
I Stainless steel exhaust. Austin Healey 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
E Moss stainless exhaust offering. Austin Healey 28
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
DornTRoriginal TR2/3/3A Stainless Steel Exhaust Installation Triumph 4
J General Tech Stainless-steel caliper pistons Triumph 8
Rob Glasgow Tourist Torphy Stainless Steel Exhaust Systems Austin Healey 27
Jeepster Mixing stainless and mild steel exhaust Austin Healey 5
TulsaFred Polished stainless steel bumpers? Spridgets 13
S TR2/3/3A radiator pipe in stainless steel Triumph 5
T Rattling stainless muffler Austin Healey 10
B Stainless hood / bonnet and trunk / bood support rods Austin Healey 2
bighealeysource Installing new stainless steel beading on BN2 Austin Healey 4
drambuie Getting a better deep throaty sound from my Stainless exhaust Austin Healey 5
60TR3A What's The Recommended Stainless Steel Exhaust for '63 BJ7? Austin Healey 5
C BJ8 Stainless Steel Exhaust - throaty sound ? Austin Healey 4
af3683 TR2/3/3A TR3 Stainless Steel Exhaust Triumph 5
M stainless push button snaps for convt boot Austin Healey 2
T Stainless Steel Fender Beads Triumph 1
G Plasma Nitrated cali vs stainless caliper pistons Triumph 1
Stinger TR4/4A TR4A Stainless Trim Installation Triumph 5
Stinger TR4/4A TR4A Stainless Door Trim Question Triumph 5
Frank C. Stainless Steel Exhaust Austin Healey 6
98Redline BJ8 Stainless Braided Brake Hoses Austin Healey 8
Stinger TR4/4A TR4A Trim Emblems Chrome Stainless Installation Triumph 3
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
I Chrome or stainless rivet source? Spridgets 21
M TR4/4A tr4a stainless fender trim? Triumph 3
R Stainless Steel Exhaust system Austin Healey 14
M TR4/4A tr4a stainless trim? Triumph 7
RJS Stainless Steel Bumpers Triumph 11
G stainless steel exhaust Austin Healey 14
T Recommendations on stainless brake lines Spridgets 13
T TR4/4A Stainless steel brake lines for a TR4a Triumph 12
T Regular vs stainless steel pistons for calipers Triumph 13
S Spitfire Stainless Steel Spitfire Bumpers on ebay- Info Triumph 7
T Stainless steel brake hoses - two questions Spridgets 13
M Spitfire Spitfire stainless exhaust deep discount Triumph 3
