What motor will fit my 1969 Austin Healey Mark IV
wergold
I am just wondering if anybody knows of a new or used motor and transmission i can put in my 1969 Austin Healey Mark IV just wondering what motors and tranys will fit the vehicle I just bought this car and I just don't know much about it I'm looking for a easy but I don't want to cut my car all up for a motor
does anyone have one for sale or know where I can get one​
G
IIRC any RWD A series should be the same or a Datsun A series motor and trans will fit with slight modification.
Jim_Gruber
So tell us what is wrong with your present engine and perhaps we can provide advice and the best way to get you driving again.
SaxMan
The 1275cc A-series motor connected to a 4-speed "ribcase" transmission is the correct motor/tranny combination. Like others have said, the Datsun A-series motor makes for a good substitute with only minor modifications. If you search the internet, you can find other engines that have been dropped into these cars, but they have required more than a fair amount of modifications and fabrications to fit. In fact, if you search this forum, there's a gentleman who has put a Small Block Chevy in his Sprite.
BTW - I own a '69 Sprite Mark IV as well. The Mark IVs may not be as iconic as the Bugeyes, but they are just as fun to drive, and we get three windshield wipers!
Jim_Gruber
That is unless you had a '68 Mark IV which only came with 2 wipers for the majority of the model year.
DanLewis
Not to mention door handles - right?
Dan
SaxMan
Well, I was talking about the '69, not all Mark IVs. The '69 also gives you the high back bucket seats.
Anyone know the approx serial of the last Sprite imported to North America was? I'm curious how close to "the end" mine was. I know by the heritage certificate the car was assembled in late April of '69, but didn't get shipped until early July of '69, finally making its way to the Chicago area in August.
58Custom
Wergold,
What amount of chassis modification and customization of the mechanical and electrical are you comfortable undertaking?
SaxMan
In that case, you're probably better off going the stock route. Even if you can only find a short block, the part suppliers such as Moss Motors and Victoria British can get you the rest of the parts. Going that route isn't cheap, so you may want to see if you can find a complete motor.
The 1275 A-engine is very easy to work on. 11 months ago, I had never touched an engine. Since then, I've replaced the head gasket, water pump, exhaust, all the hoses fan belt and played with the carbs until I was blue in the face, not to mention all the other work I've done to the car. Believe me, once you drive the car, you'll realize that the effort (and expense) is very well worth it.
Jim_Gruber
How about some pics and we can help evaluate. We live pictures. And where in UT are you close to?
W
wergold
will a original 9C engine fit and work in a mk iv 1969 Austin healey and work with out any or much modifications?
W
wergold
austion healey.jpgaustion healey side.jpgthese are the only photos I have right now I will try to get more in a day or two
JPSmit
If you are going the non- stock route, look here https://www.britishv8.org (they aren't all V8s) but do cover the range. probably a Rotary RX7 lump is the easiest due to its size. Actually an MG K series engine might be easiest but impossible to find on this side of the pond. keep us posted!
drooartz
the car is in Centerville utah
You should connect up with the British Motor Club of Utah (https://www.bmcutah.org/). We're an easy going group, no dues or anything like that. There are folks on that list that probably have the parts you need. I'm up in Midway (Heber Valley) myself.
Jim_Gruber
So what kind of rust will need repair. Thinking chassis, a post, floors, outer rockers, spring boxes. Looks like sone body work nay gave been started? Need to make sure you've got a good platform to build upon..
nomad
Well your best bet then would be a 1275 and ribcase which you can probably source on E-bay if you can't find one anywhere else. There are folk's on this forum that can probably set you up with rebuilt units ready to go for a price and maybe some offers for good used. Could also add a Datsun 5 speed for not much fabrication....its up to you!
Kurt.
Billm
That 9C motor will fit fine but it is a 948cc motor and pretty weak (around 42 hp)- they came in Sprites from '59 to '63
Your car came with a 1275cc motor which is around 70hp and is available from any MG Midget or Sprite from '67 till '74.
I would go with a 1275 if possible- it also has more aftermarket stuff available.
BillM
W What motor will fit my 1969 Austin Healey Mark IV Austin Healey 5
B Spitfire Has anyone fit a 2500 wiper motor to a spit mk1? Triumph 3
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
B Windscreen Motor Repair Restoration & Tools 6
HealeyPassion Pop Quiz: Displacement of 2912cc motor bored 30 thousands (0.030) over Austin Healey 3
W General Tech 2500S starter motor and fuse box questions Triumph 3
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
R TR2/3/3A TR3 Wiper motor Triumph 10
SNClocks Upgraded Motor Mounts Spridgets 4
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
M Engine Stand for 3000 Motor Austin Healey 7
E MGB MGB heater motor problem MG 3
edkap2002 TR6 starter motor advice Triumph 12
T Motor Jaguar 4.2 Jaguar 14
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Motor knocking at start up? Triumph 11
T TR2/3/3A wiper motor short Triumph 2
Darwin Spitfire Motor mounting help Triumph 1
3798j Off Topic My motor...it whistles... Triumph 2
60TR3A TR2/3/3A How Authoritative is the British Motor Industry Heritage Trust? Triumph 6
B TR4/4A Rubber wiper motor mounts Triumph 4
R Rewind electric motor Restoration & Tools 3
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
R GT6 Wiper Motor problem and time capsule Triumph 4
K TR2/3/3A Motor oil for Summertime Triumph 3
N TR2/3/3A Wiper motor armature Triumph 11
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
M Wiper Motor Problem Not Working Spridgets 5
J TR2/3/3A Wiper Motor bracket Triumph 5
steveg Motor mount replacements Austin Healey 3
T TR5/TR250 TR250 wiper switch and motor Triumph 1
Bayless Question on 1 speed wiper motor Spridgets 2
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
S TR2/3/3A starter motor Triumph 9
tinman58 TR5/TR250 TR 6 wiper motor Triumph 10
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
pa297pass TR4/4A TR4 wiper motor rubber mount installation. Triumph 7
AHS BJ8 blower motor switch - how to replace? Austin Healey 1
Michael Oritt Heater motor or switch problem Austin Healey 1
