TR2/3/3A Wiper Motor bracket
James A Martin
TR3B
In need of a wiper motor bracket for my TR3B, mine is pitted beyond re-installation.
I replied in Triumph classifieds but thought I'd post here with some questions.
Anyone know how to get to the mounting area for the bracket ,next to the Master cylinders, for this item? It looks like fabrication may be the only answer for me so far...
This project is not in my shop manual.
The mounting ears had nut keepers and the mounting bolts are accessible but the keepers have faded with time.
martx-5
Besides the two screws up top, there is one nut that screws onto a stud on the bracket next to the master cylinders. Access to that nut is from underneath, up by the pedal box.
Fabrication is probably the best way to go.
J
James A Martin
martx-5
Thank you for the response. The stud is OK, the ears that the two holes in the bracket bolt to, on the car, are in bad shape.
I may have to fab the bracket also.
I've seen pics of new or restored brackets here and there but none for sale....
martx-5
I guess that you are talking about the two caged nuts that the screws go into. I just put my car up on the lift to take a look. I can see the forward most caged nut under the wheel well. It looks like if you remove the mud guard piece you should be able to access the rearward caged nut. You can replace the caged nuts. They are welded on, but if you can cut them off, you can always pop rivet on new ones. I did that with some of the caged nuts that didn't allow access to weld. Doesn't look like there is such great access underneath...might be better off removing the front wing.
TR3driver
Great Pumpkin - R.I.P
Did you contact Marv Gruber? I'll bet he's got a pile of them. I'm sure I've got several myself, but not where I can get to them easily.
mgedit TR2/3/3A Wiper Motor Bracket for 56 TR3 Triumph 9
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
R TR2/3/3A TR3 Wiper motor Triumph 10
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
T TR2/3/3A wiper motor short Triumph 2
B TR4/4A Rubber wiper motor mounts Triumph 4
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
R GT6 Wiper Motor problem and time capsule Triumph 4
N TR2/3/3A Wiper motor armature Triumph 11
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
M Wiper Motor Problem Not Working Spridgets 5
T TR5/TR250 TR250 wiper switch and motor Triumph 1
Bayless Question on 1 speed wiper motor Spridgets 2
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
tinman58 TR5/TR250 TR 6 wiper motor Triumph 10
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
pa297pass TR4/4A TR4 wiper motor rubber mount installation. Triumph 7
sparkydave Wiper motor '77 Spridgets 2
J TR2/3/3A Wiper motor wiring Triumph 4
D TR5/TR250 Windshield wiper motor Triumph 9
J TR2/3/3A Wiper Motor Gear Triumph 11
S TR2/3/3A Wiper Motor Troubleshooting Triumph 6
R grease for windshield wiper motor- BJ7 Austin Healey 4
steveg Wiper motor install error - warning Austin Healey 9
P WANTED: Bugeye Wiper Motor Spridgets 0
S TR2/3/3A Wiper Motor Parking Question Triumph 8
P Bugeye Windshield Wiper Motor Spridgets 3
Jim_Stevens TR2/3/3A Wiper motor mount Triumph 4
maxwedge5281 TR6 tr6 wiper motor wiring Triumph 15
maxwedge5281 wiper motor upgrade to two speed Austin Healey 16
Scotsman TR4/4A TR4A wiper motor rebuild Triumph 8
Scotsman TR4/4A TR4A wiper motor questions Triumph 2
K TR2/3/3A Wiper motor testing? Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
rjc157 wiper motor Austin Healey 0
Rob Glasgow Wiper motor rubber mounts Austin Healey 5
J Wiper motor 100 degree sweep gear ??? Restoration & Tools 7
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
rjc157 wiper motor Austin Healey 6
D Wiper motor mounting Spridgets 0
T TR2/3/3A wiper motor parking Triumph 7
alanjohnturner TR4/4A Rebuildiing a wiper motor Triumph 8
